It is currently Oct Mon 26, 2020 7:46 pm
 Post subject: What kind of power connector is this?
PostPosted: Jun Sun 16, 2019 7:13 pm
Hi All,
I have seen these before but don't know what they are called so I can track a couple down. Thanks!
 Post subject: Re: What kind of power connector is this?
PostPosted: Jun Sun 16, 2019 7:36 pm
3-Pin HP/Burroughs/NCR connector, depending on the max oval dimension and pin spacing - there were IIRC two (maybe 3) sizes.
I have some NOS cords listed, deep in the classifieds:
viewtopic.php?f=15&t=281280
They fit the most common "HP" size, and have IEC color coded leads - you'll want to open up your instrument to verify the polarity if a hot chassis or fusing is used.
Brian
PostPosted: Jun Mon 17, 2019 12:54 am
You can find them if you search for "TV Cheater Cord" as well
PostPosted: Jun Mon 17, 2019 1:00 am
The cords occasionally show up at hamfests and surplus stores. Sometimes the seller doesn't know what they are and prices them really low. Sometimes they know they are in demand and price accordingly.
Jim Mueller
PostPosted: Jun Mon 17, 2019 5:13 am
It's called a PH-163. Very common on North American business machines and test equipment before the IEC connectors became popular.
Still being made for replacement use, at least until very recently. Should not be too hard to find one.
Note that NEMA, or whatever orginization that set a "standard", chose to reverse the L and N connection convention used by HP, so there are two types or cords. Usually either will work in the other's place.
Ted
PostPosted: Jun Mon 17, 2019 3:25 pm
Thanks folks! Much easier to locate something once you know what to call it. A friend of mine said he might have one in his stash, so I will dig and see if I can find one this week. Findem, if I don't find one I know where to get one.
PostPosted: Jun Tue 18, 2019 12:12 am
Those power cords usually sell on eBay for more than $20. I have a stash that I won't sell because some equipment can't be easily changed over to IEC. If you can make the change I suggest doing it; you will need to cut metal.
PostPosted: Jun Tue 18, 2019 12:52 am
You know, I have been thinking about that. The unit is a mid/late 50's ampex suitcase amp. Its already been modified with an extra mic jack and an external fuse holder. There is sufficient room to put in an IEC. I don't happen to have a panel mount IEC laying around either though. I guess I will see if my buddy has one (if so it will be free) and if not I'll have to decide. Findem has 'em at a good price but then there is shipping.
Anyway, thanks for the suggestion.
Users browsing this forum: Ken Doyle and 15 guests
