It is currently Oct Thu 24, 2019 3:07 am
 Post subject: G.E KS15701 Germanium Rectifier Specs/datas ?
PostPosted: Jun Mon 03, 2019 9:55 pm
I'm looking for the electrical specs for the General Electric type KS15701 L3 diffused junction germanium rectifier. Went through all my old databooks without success. Anyone here could help ? Please note I'm not looking for a substitute but the original specs. (max. PIV, forward current,etc...)
Thanks to all for your help.
 Post subject: Re: G.E KS15701 Germanium Rectifier Specs/datas ?
PostPosted: Jun Mon 03, 2019 10:28 pm
That KS-prefixed diode is a Western Electric part number. GE made it for WE,
Try some of the many WE semiconductor guides - one is at AmericanRadioHistory,com.
Brian
PostPosted: Jun Mon 03, 2019 10:50 pm
BTW, the "L3" suffix is the list number (list 3.....).
Here's the KS15724 L1 - can't seem to locate yours. TelephoneCollectors.info has the BellSystemsPractices (BSP) data.
Some later edition of C18.073 will probably have your data.
Brian
PostPosted: Jun Sun 09, 2019 3:12 am
Thanks guys for the replies. I'm still searching for the datas...
A few more infos:
The diode is mounted on a small square heatsink plate with a (insulated) L-shaped mounting bracket.
Production code stamped on the plate is 1-55 which I guess is january 1955 ?
I checked it with my semiconductor analyzer and found a forward voltage drop of 0.18V (which is normal for a Ge element) and a P.I.V breakdown voltage of 450V. The remaining missing data is the max. forward current but considering the age and technology of this diode I would guess something in the 0.2 to 0.5A range ?
Any thoughts ?
