It is currently Jul Thu 18, 2019 8:00 am
 Post subject: Hammarlund 170A power transformer
PostPosted: Jun Tue 04, 2019 2:30 am
I have a Hammarlund 170A on the bench with a DOA power transformer. How can I find the specs on the transformer, the parts list tells me nothing. TYIA
 Post subject: Re: Hammarlund 170A power transformer
PostPosted: Jun Tue 04, 2019 3:18 am
Well, the easy part is adding up all the filament loads.....:)
I found one voltage on the schematic---the "high B+" going to the output tube. 255VDC--means the HV secondary is in the neighborhood of 280 - 300 peak, or ~ 200 - 215 rms. (per side--ie from the CT to each end)
To pin things down, we'll need all the tube currents.
Much as I love reading tube data sheets, I'd probably just pull the thing apart and count the turns and measure the wire gauges
Wild Guess:
220-0-220 at 300mA DC
6.3VAC at 8 amps
But--don't guess on this one........
Users browsing this forum: Exabot [Bot], radiotechnician and 4 guests
