It is currently Jul Wed 17, 2019 4:10 am
 Post subject: Meter movement repair source found
PostPosted: Jun Mon 10, 2019 3:15 am
The tiny hairsprings in moving-coil meters sometimes come loose from soldered connections.
I was talking with a cellphone repairman who described repairing a common defect in a popular model of a popular brand cellphone. There are many connections on the bottom of a chip that can fail and which must be soldered with hot air, but one connection connects to a circuit board trace that almost always fails after the chip is replaced. The cure is to solder a wire to replace the trace. It has to be done under a microscope.
I described the hairsprings in a moving-coil meter and he said it would be an easy job under the microscope to reattach a solder joint. Your local cellphone repairman should be able to fix the hairsprings in a failed meter which cannot be otherwise economically replaced if you disassemble the meter for him and remove the magnet. Another option would be to find a web site with the meter theory for him or her to view.
The impossible again just takes a little while.
Pat W5THT
Unhappy tubes blush while unhappy power FETs scatter plastic
 Post subject: Re: Meter movement repair source found
PostPosted: Jun Mon 10, 2019 3:53 am
When he actually does the work, and charges you for repairs, let us know.
BTW, disassembling a meter and removing the magnet isn't always easy; that's like saying remove engine from car.
PostPosted: Jun Tue 11, 2019 12:02 am
If you have the tools, patience, clean room, and steady hands necessary to fully disassemble and reassemble meter movements, why would you need a cell phone repairman to solder the hairspring?
Thomas A. Edison
