It is currently Jul Fri 19, 2019 12:01 pm
Post New Topic Post Reply  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: 6x5 vacuum tube
PostPosted: Jun Wed 19, 2019 6:29 pm
Hello
I have heard some horror stories about this tube taking out power transformers. I have seen information about using a WX5 tube to correct the problem. Question is would a fuse protect the transformer from this varmint??
Regards
DaleB
 Post subject: Re: 6x5 vacuum tube
PostPosted: Jun Wed 19, 2019 6:44 pm
I think you mean a 6X5W. Yes, fusing would be recommended, if you use the correct fuse.
PostPosted: Jun Wed 19, 2019 6:50 pm
Fuses should work OK to protect the transformer. A 0.1A, 250VAC, in each plate lead would be my suggestion. The voltage may be higher than 250V but the fuses should easily clear quickly enough to protect the transformer.
There are reliable versions of the 6X5 but you never know what someone might plug in in the future.
Jay
PostPosted: Jun Wed 19, 2019 6:55 pm
A newer version 6X5 will be ok. A fuse will give the transformer enough time to be ruined. Zenith recommended fusing with a dial lamp instead. If I remember the problem was with the early 6X5 and not the later ones.
This subject has been beat to death here in the past.
GL,
Henry
PostPosted: Jun Wed 19, 2019 7:17 pm
I replaced the 6X5 in my Zenith 8S-463 with the later and better designed 6X5WGT. In addition, I added a 28 0hm 50 watt power resistor to the AC return line, dropping the incoming voltage from 121 to about 110, the voltage in effect when the radio was made.
Doing these steps should insure that your PT will remain safe. I can rest my hand on the PT after an hour of operation, and it's only warm.
The original designers saw no need for fuses in practically any of these radios, so why re-engineer?
PostPosted: Jun Wed 19, 2019 7:30 pm
The tube that was suggest as a drop in was a WX5 copper top if that means any thing looking for that now any information on that tube?
DaleB
PostPosted: Jun Wed 19, 2019 7:58 pm
If you read up on the 6X5 problem, you will find that it is only a problem in certain Zenith sets that pushed them beyond their capabilities. Everywhere else they work fine.
There is no WX5 tube. You probably mean 6X5W which is a military version. But you might consider avoiding the 6X5G which is the earliest version.
PostPosted: Jun Wed 19, 2019 9:12 pm
DaleB
What is the source of that information? Do you have a link?
PostPosted: Jun Wed 19, 2019 9:42 pm
The only one I had problems with was, in an airline, with a WG chassis. I was gettin ready to align it, and I heard
a "ping" and look over and the 6X5 had died. There was no damage, it was an original airline label tube,
So it may have just been "old age" :lol:
 Post subject: 6X5
PostPosted: Jun Wed 19, 2019 11:03 pm
www.thirdbayradios.com/6X5_Tube_Replacement.html
This site references the WX5 tube only know what I read
DaleB
 Post subject: Re: 6X5
PostPosted: Jun Wed 19, 2019 11:32 pm
I learn sumpin' new here all the time. Thx for the link. Here's a further one; https://www.tedweber.com/wx5 showing the replacement for $24.
Here's a quick search finding a vendor selling a 6X5WGT for $7.50; https://vacuumtubesinc.com/index.php/va ... x5wgt.html
PostPosted: Jun Thu 20, 2019 12:33 am
I looked for the article regarding the Zenith engineering fix and can't find where I filed it. Maybe someone has saved it?
Henry
PostPosted: Jun Thu 20, 2019 12:50 am
There have been several 6X5 threads on this forum.
Here I have photos of several versions: viewtopic.php?t=117188
Here is one of the longer ones: https://antiqueradios.com/forums/viewto ... &start=140
PostPosted: Jun Thu 20, 2019 1:24 am
I believe this is what the original poster is referencing:
PostPosted: Jun Thu 20, 2019 1:25 am
"radiohenry" states: "This subject has been beat to death here in the past." I certainly agree with him. The ARF "Search" feature will reveal hundreds of previous posts on this subject.
Jim Mueller is absolutely correct. There is now, and never has been, anything wrong with the 6X5 tube itself, which works very well in a great many applications. The bad reputation it has gained among many is due to Zenith improperly choosing this tube as a rectifier for certain pre-war AC radios whose power transformers were undersized to begin with.
Poston
PostPosted: Jun Thu 20, 2019 3:26 am
Poston Drake wrote:
uote="Jim Mueller"]If you read up on the 6X5 problem, you will find that it is only a problem in certain Zenith sets that pushed them beyond their capabilities. Everywhere else they work fine.
"Jim Mueller is absolutely correct. There is now, and never has been, anything wrong with the 6X5 tube itself, which works very well in a great many applications. The bad reputation it has gained among many is due to Zenith improperly choosing this tube as a rectifier for certain pre-war AC radios whose power transformers were undersized to begin with.[/quote]
I believe these statements accurately sum it up.
ex nihilo nihil fit
PostPosted: Jun Thu 20, 2019 5:32 am
You could install a separate 300 mA heater transformer and connect the heater to
the cathode of the 6X5.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jun Thu 20, 2019 11:57 am
[quote]The original designers saw no need for fuses in practically any of these radios, so why re-engineer?/quote]
The original designers also saw a readily available supply of spare transformers....... ;-)
www.bbtvtestequipment.com
PostPosted: Jun Thu 20, 2019 12:09 pm
Better yet, install a seperate 5 volt 2 amp filament transformer and upgrade to a 5Y3.
PostPosted: Jun Thu 20, 2019 2:52 pm
And silicon diodes in series with the plates. That will protect against plate to cathode shorts as well as cathode to filament leakage/shorts. Leaving the 6X5 in place assures that the B plus won't be applied to the filter caps until the other tubes begin to draw current. Total cost of the filament transformer and diodes is less than the fancy Copper Top replacement. I've done this on Zenith consoles that use two 6X5 rectifiers while restoring them for others. Peace of mind.
Users browsing this forum: russosborne and 9 guests
