It is currently Apr Fri 03, 2020 5:30 am
 Post subject: Source for tube retainers?
PostPosted: Sep Sun 22, 2019 1:02 am
Does anyone know where I can buy some of these wire tube retainers? They are for tall and short 9 pin tubes, 12AU7 and 6CY7.
Mine are rusty, I can clean off the rust with Naval Jelly, but that leaves them looking rather ugly.
 Post subject: Re: Source for tube retainers?
PostPosted: Sep Sun 22, 2019 7:58 am
Toss them in a vibratory tumbler. They'll clean up fine with plastic pyramid or walnut shell media.
I've used electroless nickel plating to replace the patina/plate them. A thin coat goes a long way. I've also seen Tinnit (PC board tinning solution) used to tin plate the cleaned-up retainers.
You could also jig up a bender with some steel rod/drill bits, and use piano wire to make new retainers. I've done that with relay retainers on commercial refrigeration boards where they were missing. Overbend a bit - the piano wire will spring back.
Brian
PostPosted: Sep Sun 22, 2019 8:47 am
Thanks for the suggestions, but they turned out okay after soaking in a mixture of Naval Jelly and water for a few hours, followed by wire brushing.
I thought they'd be pitted up, but they really aren't bad. You don't really see them in normal use anyhow.
