It is currently Feb Fri 28, 2020 1:50 pm
 Post subject: Master Tube Substution handbook
PostPosted: Aug Sat 10, 2019 2:01 pm
If u need to know about a tube Substution. i might be able to help out.
 Post subject: Re: Master Tube Substution handbook
PostPosted: Aug Sun 18, 2019 3:53 am
thanks, but a lot of us have tons of books galore that can help us do the same. can you elaborate upon your service ?
steve
-Churchill
PostPosted: Aug Sun 18, 2019 3:55 am
How about a direct sub for a 1L6
PostPosted: Aug Sun 18, 2019 3:57 am
I need some cheap direct subs for the 8417 and the 7027a.
steve
-Churchill
PostPosted: Aug Sun 18, 2019 2:37 pm
how about a direct sub for a 7868 ?
steve
-Churchill
PostPosted: Aug Sun 18, 2019 2:53 pm
The only direct sub for a 1L6 is a 1L6. Other tubes may be partially functional in, say, a TO, but there is no true substitute for a 1L6. Using a substitute for a 1L6 in a TO generally adversely affects the higher frequencies.
Tube substitution guides were largely an outgrowth of WWII, when most tube production was going to the military and there was a shortage of some tube types for domestic replacement purposes. Some stayed in print through the early '60s. With a fairly small number of exceptions you cannot expect equipment with a tube from a substitution guide to perform as well as it would with the correct tube. I have the Middleton tube substitution guidebooks but they are shelf queens - part of my collection of electronic works in print. I do not use them because I see no need to substitute tubes. All of the tubes that I need are still available, although some have gotten expensive.
PostPosted: Aug Mon 19, 2019 3:49 am
i tend to believe someone might be playing games in this thread.
i've only substituted one tube in my entire life due to a poorly designed circuit that used a 6SD7 where the change of a resistor and the use of the 6SG7 sealed the deal.
it was classic textbook circuitry in a late 30s AM/SW table set as motorola must have received a great deal on the horrible 6SD7, which was a total failure for the oscillator in the SW section.
as for someone providing a "service" for tube substitution, or a "master book", that gives me a chuckle.
all i need are my excellent RCA/GE Essential Characteristics books and my own four or five tube substitution books from RCA, Sylvania, GE, and a few others.
...that is, if i ever do substitute a tube (out of thousands of opportunities) for the second time in my life.
i'm out on this thread, guys.
steve
-Churchill
PostPosted: Aug Mon 19, 2019 7:45 am
I think the OP was just trying to be helpful, not knowing the knowledge and experience some members here have.
PostPosted: Aug Mon 19, 2019 7:50 am
^ I agree. It's nice to see someone offer help, vs the usual "what's it worth?" one post wonders.
PostPosted: Aug Mon 19, 2019 10:20 am
PostPosted: Aug Mon 19, 2019 2:09 pm
"Oh Stewardess, I speak Jive"...
PostPosted: Aug Mon 19, 2019 2:31 pm
oops--my mistake
-Mark
PostPosted: Aug Fri 23, 2019 4:46 pm
1U6
Kim Herron
W8ZV
kim.herron@sbcglobal.net
616-677-3706
PostPosted: Aug Fri 23, 2019 5:03 pm
That's what is often listed a sub for 1L6 but filament current is half. Won't work in a radio with series wired filaments unless a resistor is added. Most 1L6's are in series string radios.
PostPosted: Aug Fri 23, 2019 5:52 pm
I just don't substitute tubes. No reason to as pretty much any one I need is readily available, though sometimes a bit costly. Transistors are a different story. I will sub them as needed.
PostPosted: Aug Fri 23, 2019 5:57 pm
Can I use a 304CRES tube for a 316CRES tube? :?: 8)
Brian
PostPosted: Aug Fri 23, 2019 8:05 pm
I prefer 304L tube when I have to weld it. :roll:
PostPosted: Aug Sun 25, 2019 6:37 am
Kids rummaging around in the garbage cans of telephone exchanges,
and tv/radio radio shops learned that you used what you got your hands on.
Small wonder the old geezers today wont throw out old tubes. :D
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Aug Sun 25, 2019 4:54 pm
Try find a sub for a Rogers 6F7M, with out doing some wiring changes.
So far , I am told that there is no sub for this tube.
They are like hens teeth
Rogers had some tubes that were their own, and had no sub.
Dan in Calgary
PostPosted: Aug Sun 25, 2019 7:24 pm
The 6F7 is/was a common tube. Dip one in silverink metalized coating. Then make a ground
contact loop around the top of the base.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
