It is currently May Thu 28, 2020 2:35 am
 Post subject: mica caps -what voltage to order
PostPosted: Mar Thu 26, 2020 1:05 am
Hi to everyone, I will be recapping a 1948 ge radio. there are some mica caps in the circuit. The schematic gives voltages for all the rest of the caps, but not for the the mica. Mouser has a choice between either 500 volts or 1000 volts for the mica caps which ones should I go for?
my thanks in advance
 Post subject: Re: mica caps -what voltage to order
PostPosted: Mar Thu 26, 2020 1:13 am
500 should be fine for a radio.
Scott.
PostPosted: Mar Thu 26, 2020 2:54 pm
Why do you believe the micas need replaced? Not that they may not, but I have never had issues with them in AM BC radios of the common types. That does not include the ones that get noisy in IF transformers, I am speaking of the postage stamp types in the RF circuits. They could go bad but nothing like paper caps in the rest of the radio.
PostPosted: Mar Thu 26, 2020 3:00 pm
As a general rule, I do not replace micas "on sight". But, there are some brands generally reported to be trouble. One good method is to test a few---if bad, then replace all similar.
In the RF and IF circuits, the common rating of 500 volts is more than adequate.
Consider buying an assortment from someplace like JustRadios or Sal's
Users browsing this forum: Google [Bot], Hotpeppers, khutch, mrriggs, Number 6, regenfreak and 9 guests
