It is currently Sep Sat 19, 2020 3:49 pm
 Post subject: Grunow 470
PostPosted: Aug Mon 10, 2020 1:18 am
I hope this is the right forum.
I am working on a Grunow. The previous owner must have some work on it, specifically the E-caps. Is there a way to find out the capacitance, voltage, and number of E-caps needed in this radio?
 Post subject: Re: Grunow 470
PostPosted: Aug Mon 10, 2020 1:25 pm
The one nearest the 80: 22mfd., next in line: 33mfd and any more, too. 400-volt ones are fine. Enjoy! Craig
PostPosted: Aug Mon 10, 2020 1:42 pm
This shows two 8uF electrolytics:
http://www.nostalgiaair.org/pagesbymode ... 008353.pdf
(There are actually 2 schematics there, and I can't immediately see the difference between them)
Is this the radio?
https://www.radiomuseum.org/r/general_ho_470.html
"Voltage is fun to watch, but it's CURRENT that does the work."
PostPosted: Aug Mon 10, 2020 3:11 pm
This is the radio. Thanks!
PostPosted: Aug Mon 10, 2020 3:33 pm
Is this the radio?
The power transformer in this radio is oozing goo. My guess is that I need a new one. The old e-caps were 22 and 18. Do you think this contributed to the damaging of the power transformer?
PostPosted: Aug Mon 10, 2020 3:51 pm
First, look at the schematic I linked and see if it matches your set.
Transformer:
"oozing goo" is not unusual---the key is whether it overheats. What you need is a no-load test---easily done by removing all the tubes. Ideally, hook the set up to a Variac so you can control the voltage. At the specificied input voltage, the transformer---with no load---should get only barely warm after 20 minutes or so.
PostPosted: Aug Tue 11, 2020 6:07 pm
In most cases an 80 rectifier is good for up to 32 uF input so that's unlikely to have been the cause of failure, if it is indeed bad. (Although a shorted cap would eventually cause a transformer failure.)
Is this the radio?
PostPosted: Aug Tue 11, 2020 6:09 pm
pixellany wrote:
First, look at the schematic I linked and see if it matches your set.......
cron
