It is currently May Sun 09, 2021 12:16 am
 Post subject: Sylvania M-R Z5R Vacuum Tube
PostPosted: Feb Mon 22, 2021 10:28 pm
Hello, I think I have a bad tube. It's not heating up or lighting up at all. It is a Sylvania M-R Z5R from a GM Cosmopolitan 252 radio. Does anyone have one and a source for one? Is there a replacement? Thanks.
 Post subject: Re: Sylvania M-R Z5R Vacuum Tube
PostPosted: Feb Mon 22, 2021 10:36 pm
That isn't the number of your tube.
M-R = Maintenance and Repair, which indicates a tube manufactured during WW2 for civilian use.
Z5R is most likely a date code.
Look at the tube layout for your set and see which tube it is.
PostPosted: Feb Mon 22, 2021 11:02 pm
Rodney linked to the nostalgia air schematic here...
General Motors model 252
viewtopic.php?p=3339416#p3339416
Tube layout diagram.
PostPosted: Feb Mon 22, 2021 11:26 pm
Would this bulb recent music from the speaker? I’m only getting static.
PostPosted: Feb Mon 22, 2021 11:37 pm
This radio is around 90 years old.
It needs to be completely assessed and restored by a competent technician.
You just can't plug it in and hope for the best.
If you discovered a 90 year old car in a barn - - - you wouldn't expect to drive it down the freeway - - - would you?
PostPosted: Feb Tue 23, 2021 6:56 pm
It is also possible that someone stuck in an incorrect tube just to fill the empty socket, which will keep it from working. Check all the tubes against the tube layout diagram to be sure.
