It is currently Jul Sun 25, 2021 10:16 pm
 Post subject: philico H-1961
PostPosted: Jun Sat 05, 2021 2:33 pm
Hi all I have picked up a Philco model H-1916 console made in 1960 0r 59.
I will be restoring this and do not have the 36-1674 electrostatic speakers.
looks like there very hard to find.
This has a very interesting output wiring setup I am anxious to get working.
Does any one out there have a pair of these speakers?
if not what's the best way to incorporate standard speakers to this circuit?
Sam's set 484 has schematic's
 Post subject: Re: philico H-1961
PostPosted: Jun Sat 05, 2021 9:33 pm
Can you provide a link to more information on this unit? An online schematic? Perhaps Egg will step in if you cant locate anything.
Meanwhile here are some possibilities. I would guess the things to look for are high sensitivity and low crossover frequency. The cheaper tweeters may actually work better because they match up better with a Philco sort of system.
https://www.parts-express.com/speaker-c ... evel12:asc
https://www.parts-express.com/speaker-c ... s/tweeters
Ted
PostPosted: Jun Tue 08, 2021 1:05 am
It appears that the remote speakers had a 2 x 10" midrange as well as the electrostatic tweeter and crossover, so I assume you only have the center channel 12" woofer. May be easiest to connect some 4 Ohm full-range speakers and disconnect the woofer. Note that the two channels are out-of-phase to sum in the woofer, then one has the wires crossed in the interconnect cable so that the remotes are in phase. The -600V on the speaker cable could give you a buzz... fortunately limited by a 2 meg resistor.
PostPosted: Jul Fri 16, 2021 12:11 am
found a pair of electrostatic speakers same as came with stereo!
Will post when i get the unit working.
