It is currently Oct Mon 25, 2021 2:49 pm
 Post subject: Question about the grids in a 6SA7 tube
PostPosted: Sep Tue 21, 2021 8:36 pm
I am about to try aligning a set which uses one of these tubes as the converter.
To align the two IF transformers, the instructions say to apply the signal generator output "....to the converter grid....".
This tube has 5 grids and I am totally uncertain if the appropriate grid is 1, 2, 3, 4, or 5 (numbering out from the cathode).
Thank you for your advice.
Joseph
 Post subject: Re: Question about the grids in a 6SA7 tube
PostPosted: Sep Tue 21, 2021 9:13 pm
It's the one which the antenna signal connects to, in a pentagrid tube like the 6SA7 that would be G3.
PostPosted: Sep Wed 22, 2021 4:09 pm
Thank you Mr. Detrola!
Exactly what I needed to know.
Joseph
PostPosted: Sep Wed 22, 2021 5:03 pm
In a typical pentagrid converter tube like 6/12SA7 or 6/12BE6, G1 is the oscillator grid, G2 is the oscillator "plate," G3 is the input of antenna grid, G4 is the screen grid, and G5 is the suppressor.
PostPosted: Sep Wed 22, 2021 6:32 pm
Thank you Chris!
Joseph
PostPosted: Sep Wed 22, 2021 10:11 pm
From the RCA tube manual
6SA7.pdf [122.33 KiB]
Downloaded 13 times
"There Is Nothing Finer Than A Stromberg-Carlson"
