It is currently Feb Mon 17, 2020 5:38 am
 Post subject: Motor question
PostPosted: Nov Sun 21, 2010 7:45 pm
This question is for the motor experts on the forum:
Lets say you are working on a single phase 120 volt induction motor with no start or run capacitor.
If you were to apply 120 volts to the stator with the rotor removed, would it draw more or less current that with the rotor in place?
I've been doing some experiments and some of my results are not what i thought they would be.
PostPosted: Nov Sun 21, 2010 8:37 pm
I would expect more, because its inductance is lower. But then, if the iron doesn't saturate, its inductance might be higher. It wouldn't saturate without the return magnetic path through the rotor.
PostPosted: Nov Mon 22, 2010 5:55 am
I would expect more current because the armature is not in place and rotating to cause a counter EMF to be generated in the field coils which opposes the current in the field.
http://en.wikipedia.org/wiki/Counter-el ... tive_force
However beautiful the strategy, you should occasionally look at the results.
Winston Churchill
PostPosted: Nov Sat 27, 2010 9:08 pm
Thank you for the replies and the link.
I had initially thought that since the rotor was not installed and this is the focus of the work of the motor then the current draw would be less than rated. In other words no rotor, no load, minimum current.
That's what I thought.
But with your responses and that link I see my error in thinking. I didn't think about the interacting flux.
Now that I have the motor reassembled, the current draw is 0.5 amps at 110v - just as it should be according to the motor rating.
Without the rotor, the current is almost twice that.
Very interesting and a good learning experience - another reason I like restoring things.
Alan
PostPosted: Nov Sat 27, 2010 9:54 pm
With the rotor in and prevented from turning
what is the 'locked rotor' current?
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Nov Sat 27, 2010 11:47 pm
Should be 10 or 20 times the full-load current, essentially limited by the DC winding resistance.
Users browsing this forum: Alan Voorhees, davep, Dirt Bomb, WoodchuckTN and 22 guests
