It is currently Sep Sat 18, 2021 6:15 pm
 Post subject: Compressor Oil
PostPosted: May Thu 16, 2019 5:17 am
I had to buy a new air compressor today; my Sears compressor started spitting ball bearings so it went to the curb.
The new McGraw 20 gallon uses 30w non detergent oil. So, is synthetic oil better? What should I get?
 Post subject: Re: Compressor Oil
PostPosted: May Thu 16, 2019 8:36 am
Not too sure you could even find a non-detergent synthetic. It does need to be ND unless you have a pressurized, filtered lube system. Some of the larger, screw pumps do use a synth, but they operate on a completely different lube principle that a reciprocal pump.
I'm right 97% of the time. Who cares about the other 4%!
PostPosted: May Thu 16, 2019 11:16 am
What few reciprocal compressors I've seen, including two stage types, use a simple splash oil system of some sort. I've just used good quality automotive oil my compressors, and changed it on or about new years day every year for the last 3 decades or so. Like any other mechanism, keeping the oil clean is the key to long life.
PostPosted: May Thu 16, 2019 11:57 am
Likely best to use whatever oil the manufacturer says to use and change it at least as often as they say. Their engineers designed it with a known lube spec in mind
PostPosted: May Thu 16, 2019 12:17 pm
I have run Husky (Home Depot) compressor specific oil in my 80 gallon, 2 stage unit for 15 years and it has performed well so far. Just make sure you change it at recommended intervals. I don't think that full synthetic vs blended oils will make any difference unless you are a heavy commercial user, like an automotive repair shop. Most important is to make sure it is non-detergent so that it does not foam up.
Your weak point is not going to be the oil, but rather the quality of the parts that make up the unit.
PostPosted: May Thu 16, 2019 2:47 pm
Home Depot sells the Husky Synthetic Blend Non-Detergent Compressor Oil.
https://www.homedepot.com/p/Husky-Synth ... /205183905
You get a few thousand hours more run with that than standard oil:
https://mastertoolrepair.com/air-compre ... 4_445.html
Brian
Users browsing this forum: AB, dholland, Terry Judkins and 30 guests
