It is currently May Sun 31, 2020 12:44 am
 Post subject: How do you remove permanent decals:
PostPosted: Jul Tue 02, 2019 3:03 am
Like the ones from the vehicle dealership and really any of the ones like coachmen catalina from the sides of a camper and all the rest of them.
I know you can eventually grind and sand them off. I have seen some weather in the sun for 40 years and are still stuck in place.
Rodney
 Post subject: Re: How do you remove permanent decals:
PostPosted: Jul Tue 02, 2019 3:31 am
If you mean the typical graphics decals as found on commercial vehicles, or the like, I use a heat gun and a plastic scraper of sorts, similar to a Bondo spreader. Takes some patience, but unless you're over zealous with the heat, no harm will result to the pain underneath. Pretty warm, but not hot. Never checked the actual temperature when removing such decals.
I'm right 97% of the time. Who cares about the other 4%!
PostPosted: Jul Tue 02, 2019 3:32 am
I use a heat gun.
Joel Walker
PostPosted: Jul Tue 02, 2019 5:22 am
Use some 3M trim tape remover, it will take it off, but it takes elbow grease.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Alan Voorhees
Users browsing this forum: dave vincent, DCS, Dennis H., Jimmler, K9DXL, Radiosmoker, westcoastjohn and 15 guests
