It is currently Feb Tue 25, 2020 7:32 am
 Post subject: ***
PostPosted: Jun Thu 13, 2019 11:05 pm
 Post subject: Re: Finally a new bench!!
PostPosted: Jun Thu 13, 2019 11:22 pm
Holey moley! Now THAT is a Work Bench!!!
Great job Jon! That will serve you for a long time to come! :D
PostPosted: Jun Thu 13, 2019 11:38 pm
PostPosted: Jun Thu 13, 2019 11:40 pm
Dang sweet! I like the upper and lower lights. I recently installed an LED shop light in my workshop...can never have too much light when working on these things.
My collection: https://www.radiomuseum.org/collection/ ... ickel.html
PostPosted: Jun Fri 14, 2019 12:03 am
Love the old lamp on the bench. 40s "vintage?"
RW
"I'll do the thinnin' around here!"-Quickdraw McGraw
Nicely done, Jon.
I too like the LED lighting and have one over each bench.
Your storage/lighting hood has me think about adding one to at least one of my benches.
A good bench, as you now know, gives you a whole different feeling as you work.
73, de Chuck K4CCW
PostPosted: Jun Fri 14, 2019 12:12 am
Kind of disappointed Jon... I feel that the finish on this cabinet is not up to your usual high standards. Perhaps you should consider sending it to Fred Taylor for some spit and polish! ;-)
Aloha, Ken
No Console Left Behind!
PostPosted: Jun Fri 14, 2019 12:18 am
For those of you without a shop's Big-switch...
viewtopic.php?p=2844019#p2844019
If you want to paint it, water based eggshell (slight sheen) is pretty tough and there is no long lasting (overpowering) smell like the oil based type.
Neat bench... :)
PostPosted: Jun Fri 14, 2019 12:21 am
Looks good. Not sure I would leave that big 18" sitting on the floor under the bench :roll:
PostPosted: Jun Fri 14, 2019 12:53 am
Nice job on building that work bench, If I lived near buy I could have put a nice finish on it and we could have traded out, do some electrical on a few of my radios for a nice finish. Looks good without it.
PostPosted: Jun Fri 14, 2019 12:57 am
WOW!
The antique speakers are a nice touch!! :D :D
PostPosted: Jun Fri 14, 2019 1:32 am
About a year ago I realised I was rarely doing anything on the bench lately. So I rebuilt an abandoned one in the basement and moved everything down there. It made all the difference. I've been busier down there then I have been in the last 10 years. A new bench/work room makes a difference.
PostPosted: Jun Fri 14, 2019 1:42 am
Very nice
Skippy
PostPosted: Jun Fri 14, 2019 2:38 am
I like the upper light / storage hang shelf. Great way to add space and lighting when the ceiling is already finished.
Why waste time and effort cutting up a good ceiling when the same time and effort adds both light and space.
PostPosted: Jun Fri 14, 2019 3:42 am
Power strip on the front. Looks recessed enough to be safe. I was standing and leaning forward when I blew my zipper apart on a work bench when the little flip up fly part went into the hot side and the metal zipper part pressed on the grounded metal case of the power strip, big blue flash, smoke, and a loud bang. Man did I rush to the bathroom to check for equipment damage while everybody in the room was hooting and hollering. Other than my zipper and pride, no problems.
PostPosted: Jun Fri 14, 2019 3:48 am
The only problem I can see with that new bench is that you can still see some of the work surface but of course that shouldn't last long.
Other then that it is perfect.
Knowledge is useless unless you can share it. KA5OBI
PostPosted: Jun Fri 14, 2019 3:49 am
Well done, Jon!!
A new bench providing more room to spread out, definitely makes a big difference. I built a new test bench a few years ago and it made things a lot easier.
You might also consider a plug strip on the back and add a couple holes to snake power cords through.
PostPosted: Jun Fri 14, 2019 3:55 am
Inspirational - I've been thinking of going low/sit down lately and this just might push me to do it!
Have a warm, heaping bowl full of Loosener's Castor Oil Flakes—with real glycerin vibrafoam!
 Post subject: ***
PostPosted: Jun Fri 14, 2019 10:32 pm
 Post subject: ***
PostPosted: Jun Fri 14, 2019 10:36 pm
Post New Topic Post Reply  [ 30 posts ]  Moderator: Alan Voorhees Go to page 1, 2  Next
Users browsing this forum: wireless 12 and 11 guests
