It is currently Nov Wed 13, 2019 1:18 am
 Post subject: Obtain The Charging Plug For Briggs 12.5 HP Engine (Solved!)
PostPosted: Jun Tue 18, 2019 7:35 pm
Hi guys. Can any of you tell me where I can pick up the 2 pin female plug that will fit the 2 pin male plug (as pictured)? I know that I'm also going to need an inline fuse, and some 18" of wire as well.
The 2 pin male plug (pictured) is approximately 13.0mm (0.51") across, and 8.3mm (0.33") wide.
The 2 pin male plug comes off the magneto of the 12.5 HP Briggs & Stratton lawn mower engine, and there is a diode on the red wire immediately behind the male plug. What I need is the 2 pin female plug. Thanks!
Briggs & Stratton 12.5 HP Lawn Mower Engine (Photo 2).jpg [ 333.17 KiB | Viewed 1276 times ]
 Post subject: Re: Where To Obtain Charging Plug For Briggs 12.5 HP Engine
PostPosted: Jun Tue 18, 2019 7:51 pm
Write down the model # of the engine and look up the parts list on briggsandstratton.com
It will have the mating connector part number.
Probably will be 398661
Scott.
PostPosted: Jun Tue 18, 2019 8:05 pm
Thanks for the tip. The engine model number is 286707-4529-E1 so I'll look it up.
PostPosted: Jun Tue 18, 2019 8:24 pm
Hmmmmmm........I'm still searching for the 2 pin female plug wiring harness for this.
PostPosted: Jun Tue 18, 2019 9:40 pm
Used to be able to get plugs/sockets like that from Radio Shack :? :roll:
PostPosted: Jun Tue 18, 2019 11:47 pm
Given the model #. they show the cable part number as 398661
Scott.
PostPosted: Jun Wed 19, 2019 12:00 am
Might be ref number 356, aka part number 398808, listed as a “wire stop”. Has a female plug with 2 wires on it. Shows it to be for the alternator section I think, for your model engine.
- Vince
PostPosted: Jun Wed 19, 2019 12:10 am
Okay. I'll go with Part No. 398661. Thanks Scott!
PostPosted: Jun Wed 19, 2019 12:19 am
Vince wrote: "Might be ref number 356, aka part number 398808, listed as a “wire stop”. Has a female plug with 2 wires on it. Shows it to be for the alternator section I think, for your model engine."
It could be, but it shows it as being a plug with two black wire leads. I think that these Briggs & Stratton parts outlets really need to straighten out their inventory so as to make things clear.
PostPosted: Jun Wed 19, 2019 2:00 am
Dont waste any time, cut it off, splice in any plug you like....WA7OPY
PostPosted: Jun Wed 19, 2019 3:01 am
WA70PY wrote: "Don't waste any time, cut it off, splice in any plug you like..."
That's certainly an option, but I would have to install another diode if I did. You see, the original diode is connected behind the 2-pin male plug. The diode is that taped up part on the red wire (see the first photo).
PostPosted: Jun Fri 28, 2019 11:50 pm
Yep, the Part No. 398661 worked all right. I finally received the plug in the mail yesterday, and installed it (along with a 0.5A fuse holder - Radio Shack Part No. 2701281) today. Yes, I verified with a digital voltmeter that the battery was indeed being charged. Thanks for all your help guys!
PostPosted: Jun Sat 29, 2019 12:45 am
What is the 0.5A fuse for?
The charging coils are rated at 4 to 9 amps depending on options. The lighting winding normally about 2.A
Scott.
PostPosted: Jun Sat 29, 2019 1:03 am
The 0.5A fuse is used as protection for the magneto in case the battery cells short. In this set up, the battery is apparently being trickle charged. I mean, shortly after I started the engine, the battery voltage was at 12.52 VDC. About 1.5 minutes later, the voltage had rose to 12.71 VDC so it appeared to me that the charging circuit was in fact working.
PostPosted: Jul Tue 02, 2019 12:55 am
Still seems odd as I have worked on dozens of 12-20HP engines in riding mowers and all had 15 to 20 amp fuses.
Most charge at only a few amps, you will typically see less than 13V but thery are charging.
Scott.
PostPosted: Jul Tue 02, 2019 2:55 am
Scott wrote: "Still seems odd as I have worked on dozens of 12-20HP engines in riding mowers and all had 15 to 20 amp fuses.
Most charge at only a few amps, you will typically see less than 13V but thery are charging."
Well, what you seen in my write up was exactly what transpired. Please read it again. After a full 2 minutes of the engine running, that 0.5A fuse was still intact. Now how would a AGC 0.5A fuse last for 2 full minutes if the load was actually several amps? That was why I simply figured that the battery was being trickle charged. In fact, I mentioned to my brother today what other ARF members had commented, and he immediately told me that the battery was only being trickle charged.
Edit: Yes, you read it right. That was a AGC 0.5A fuse that I installed, and not a MDL.
PostPosted: Jul Thu 11, 2019 3:20 am
Update: Well, I mowed the lawn for a good 2 - 2.5 solid hours today with the lawn mower. Afterwards, while the engine was still running, I measured 12.60 VDC at the battery so the charging circuit is obviously working. I won't perform any more voltage checks with this so it looks like I got a winner. Thanks again for your help guys!
PostPosted: Jul Thu 11, 2019 4:09 am
looks like a Snapper.
PostPosted: Jul Thu 11, 2019 5:09 am
Simplex1040 wrote: "looks like a Snapper"
Yep, that's what it is all right.
PostPosted: Jul Thu 11, 2019 1:42 pm
Auto parts should have it. If not you could replace it with a mating pair. Try napa
Post New Topic Post Reply  [ 25 posts ]  Moderator: Alan Voorhees Go to page 1, 2  Next
Users browsing this forum: 8417, DCS, Flipperhome, Stan the Man, WoodchuckTN and 9 guests
