It is currently Oct Wed 27, 2021 9:05 am
 Post subject: 2" mast extension tube for antenna
PostPosted: Sep Tue 21, 2021 3:30 pm
i need to raise my antenna a few feet to clear the roof. I am having troubles finding a 2" OD mast extension tube with crimped end i can drop in. maybe someone here has a source.
 Post subject: Re: 2" mast extension tube for antenna
PostPosted: Sep Tue 21, 2021 5:54 pm
Find someone who has a discarded beam antenna that used a 2 inch diameter boom.
I assume you really want a swage mast not a crimped mast.
https://www.manualman.com
PostPosted: Sep Tue 21, 2021 6:50 pm
i want something with an end like this, whatever its called.
Are all j-poles 2 inch OD?
I think i found what i need here
https://www.cableandwireshop.com/satell ... -2-od.html
PostPosted: Sep Wed 22, 2021 2:06 am
is it steel pipe or conduit pipe tower?
PostPosted: Sep Wed 22, 2021 2:37 am
I don't know the size of your antenna or length of the extension.
Neither am I an engineer so maybe it don't matter.
If you can use electrical conduit a muffler shop might can swage the end for you if they have the correct dies.
They might even have the 2 inch pipe, it usually also comes in galvanized flavors. Its not an unheard of size.
Edit: An electrical contractor might be another possibility if they have one of those Greenlee hydraulic machines.
A complex machine that works evolved from a simple machine that works
PostPosted: Sep Wed 22, 2021 3:34 am
What are you trying to do? Your first post sounds like you are trying to extend your mast. But then you talk about a J-pole antenna. Which is it, the mast or the antenna. I hope it is the mast because the piece you describe would be a poor choice for an antenna.
Jim Mueller
PostPosted: Sep Wed 22, 2021 2:31 pm
I am not an antennae professional.
I have this, it looks exactly like it. i thought they were called J-pole, maybe not, maybe so
its a few feet tall. i have my fm antenna mounted to it. the pole is not tall enough to clear my roof. I want to extended it a few feet to clear the roof. I want to drop an extension in the top hole of the existing pole instead of replacing the whole thing. The OD of the pole is 2 inches and is probably steel i dont know the material of the pole, it is powder coated so perhaps it is steel.
I found this extension but its galvanized, will it work or not? should i keep searching?
thank you
PostPosted: Sep Wed 22, 2021 3:26 pm
thank you
The link you posted should work fine. Galvanized will outlast the powder coat. The only trouble I can see is that your mount may be too weak to add a 5' extension, considering wind load.
Dan
PostPosted: Sep Wed 29, 2021 2:26 pm
Thank you for confirmation. My antenna seems to be mounted on an old directTV mast which has the OD 2"/ ID 1.66" The link i posted is out of stock but I found this one https://www.3starinc.com/satellite_tv_a ... ch_od.html
i may have to cut it to desired length.
Post New Topic Post Reply  [ 9 posts ]  Moderator: Alan Voorhees
Users browsing this forum: DaleMidori, fifties and 9 guests
