It is currently Jun Thu 04, 2020 9:04 am
 Post subject: Help please, speaker sound but no reception Zenith Y723
PostPosted: Oct Wed 09, 2019 9:42 pm
1st thought, easy fix. It had a blown Bumblebee cap going to the rectifier, plus I found a wrong tube installed. I changed out all the paper caps and from that point I have good speaker sound but still no radio stations. My knowledge and test equipment are very limited, cap, resistor and multi meter tester. This is a beautiful radio and any help would be much appreciated, thanks - Ray
 Post subject: Re: Help please, speaker sound but no reception Zenith Y723
PostPosted: Oct Thu 10, 2019 8:11 pm
I see a few potential problems. You say that the bumblebee cap to the rectifier was blown, yet the original selenium rectifier is still in the radio. Is it putting out proper voltage? I also see that an original disc cap is still installed across the line. These are known to go bad and severely limit voltage into the set. Third, from all the markings on the IF cans, it looks like someone thought this set may have had SMD and tried to rebuild the cans with new mica caps (rather common for this series of Zeniths). Maybe they screwed up the rebuild, closed up the set and sold it as nonworking? This is all rather academic though. At this point you'll need to get hold of a schematic and start measuring voltages.
PostPosted: Oct Thu 10, 2019 10:04 pm
Eight-page service manual, should you require it, thanks to Bill J.
viewtopic.php?p=2134559#p2134559
Edit: Previous discussions regarding Y723 here at arf...
Y723 site:antiqueradios.com
https://www.google.com/search?q=Y723+si ... radios.com
PostPosted: Oct Sat 12, 2019 2:46 am
Both AM and FM are dead? The suspect is the tube that is shared by both, and the IF transformers either side of that tube.
If a wrong tube was installed, was the wiring to that socket altered?
Try to zero in on the section of the schematic where the audio signal stops. Good luck.
Burl Ives, RIP, oldtimer.
[:l>)
Users browsing this forum: Tim and 5 guests
