It is currently Jun Sun 13, 2021 9:16 pm
 Post subject: 78 question
PostPosted: May Tue 11, 2021 2:28 am
I was looking though some 78's I got... I found one of Peter cottontail by Gene Autry. I noticed the leading edge was crumbled in spots , and it looks like there is a cardboard substrate in the center of the record...I have never seen this before , unless this was considered a children's record and made cheaper?
 Post subject: Re: 78 question
PostPosted: May Tue 11, 2021 2:38 am
I know the red label Columbia 78's in the 40's (which is probably the label of your Autry record) had a cardboard base or substrate as you say and just a thin layer of shellac on each side. As a result, they won't crack all the way through but it's common for them to develop a lot of fine cracks because of how thin the shellac layers are.
Greg V.
West Bend, WI
Member WARCI.org
PostPosted: May Thu 13, 2021 8:35 pm
Yep... exactly what mine looks like as well... Guess I better get it recorded into the computer before it completely disintegrates...
PostPosted: May Fri 14, 2021 2:42 am
If it's a 10" or 12" record, chips on the edge may be from playing it on an old style changer where the mechanism was on the outside rather than in the spindle.
Jim Mueller
