It is currently Nov Sat 27, 2021 12:47 am
 Post subject: Flyback transformer help!
PostPosted: Sep Fri 24, 2021 5:07 am
I was repairing this RCA 8-PT-7011 when the wire going to pin one on the flyback transformer broke at the base and I can't get to it. The only thing I can think of is by partially unwinding the back since that connection is at the end of the winding. Any ideas?
File comment: Schematic
File comment: Transformer
 Post subject: Re: Flyback transformer help!
PostPosted: Sep Fri 24, 2021 1:48 pm
At this point, I don't think you have anything to lose by attempting that nor do I see any other possible way to retrieve the end of that wire.
However, I think that if you simply moved the connection from pin 1 to pin 2 and eliminated the width coil, the set would work although the picture may be too wide.
PostPosted: Sep Fri 24, 2021 3:22 pm
How close is the RCA 8-PT-7011 to the RCA 8-PT-7030? I have several of them and surely am not going to restore them all. I would probably have a flyback that I could extract for you. But I will be away for about two and one half weeks from now. Just a thought.
PostPosted: Sep Fri 24, 2021 5:26 pm
I was able to get the wire back, unfortunately then one of the wires for pin 3 snapped. Guess thats what I get for messing around with this tech :/
PostPosted: Sep Fri 24, 2021 5:28 pm
Don the main difference is I think on the 7030 the flyback has a separate tap for the damper tube so idk if i can use that model flyback :/
I'll keep trying and see what I can manage.
PostPosted: Sep Fri 24, 2021 6:52 pm
OK, thanks for getting back to me. I don't seem to have a schematic for either model of the RCA to compare.
PostPosted: Sep Fri 24, 2021 9:19 pm
Nomking, according to the RCA service data, which I think you have, they all use the same flyback, #102985.
They are wired differently with some chassis not using one of the taps.
Tim
PostPosted: Sep Fri 24, 2021 9:43 pm
The Flyback on these is enclosed in a metal case, there's no caps inside so curious how/why you took this apart?
PostPosted: Sep Sat 25, 2021 5:59 am
The previous owner overheated it and damaged some bits inside the caseing
PostPosted: Sep Sat 25, 2021 6:00 am
If they are all the same model transformer then I guess that transformer would work after all. Would you have any contact info don?
PostPosted: Sep Sat 25, 2021 6:29 am
I used to have some parts chassis out in the garage, can’t remember if they’re still there but I can check tomorrow.
PostPosted: Sep Mon 27, 2021 12:32 pm
If you know the merrit hvo number I might have one
PostPosted: Sep Tue 28, 2021 2:20 am
102985 is not even listed in my 1966 Merit book. Thordarson does list the number, but gives no sub.
PostPosted: Sep Tue 28, 2021 3:17 am
i don't recall that there were ever any aftermarket replacements for that one, you could only get them through RCA parts.
PostPosted: Sep Tue 28, 2021 6:53 pm
I looked through my parts stash and no luck. These sets are common as dirt, a junker should show up eventually.
PostPosted: Sep Wed 29, 2021 1:14 pm
Sorry for the delay in responding. I am on vacation right now, out of town. As with all members here, you can us the PM or private message function. I am sure that one of the sets I have can be parted out.
I figured those sets probably used similar components.
I will be back home next week.
PostPosted: Oct Sun 03, 2021 5:34 am
I was able to get the leads back and they all test positive for continuity!
I'll be able to test it later tomorrow!
PostPosted: Oct Wed 06, 2021 5:13 am
I'm gonna guess it would be ok to use 36 awg wire to make the connections from the transformer to the socket and terminals? The original used that so I assume its ok?
PostPosted: Oct Wed 06, 2021 6:13 pm
It does not matter what gauge wire you use as long as it is light enough to not stress the wire from the flyback when you bend it to connect it to the terminal.
PostPosted: Oct Wed 06, 2021 11:37 pm
I don't know where you came up with 36 gauge wire, that would be as thin as a fine hair (0.005 inch dia). Even 30 (0.010 inch dia.) gauge is extremely fine. Maybe that was a typo, 26 gauge might be about right. You might try using a strand from a copper power cord.
Tim
Post New Topic Post Reply  [ 24 posts ]  Moderators: Mr. Detrola, 7jp4-guy Go to page 1, 2  Next
Users browsing this forum: jimmc and 6 guests
cron
