I was looking for the right alignment tool to adjust I-F and trap transformers. The particular one I was looking for had a small metal blade inside of a plastic shaft. You cannot use a metal screwdriver because 1) the blade is too thick and will eventually strip the adjustment head, 2) a metal shaft will detune the circuit, and 3) in tight spaces there is a shorting danger and shock hazard. For the last two reasons, you definitely cannot use the small watch repair screwdrivers, even if the head is thin. I thought I had finally found what I needed on eBay, but it never arrived! That is when I decided to make my own. This trick may be useful to others, so I am posting it hear. If you see any potential problem or have an idea for improvement, please let me know.
All you need is a an old Bic pen and a razor blade. I used a nibbler to slice a triangular piece of the razor blade that I then wedged and glued into the top of the pen. Here is how it all came together.
