It is currently Jul Tue 23, 2019 12:04 pm
Post New Topic Post Reply  [ 80 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Predicta 10L43 First Powerup...squashed raster
PostPosted: Apr Tue 16, 2019 3:05 pm
Tom, and everyone else at the forum: I do believe I've found my problem! Looks like the I've got a bad VR1-A Height pot. Because the voltages going in were fine, but coming out were in the millivolts. Basically nothing. I tested the leads of the pot, and got zilch as far as resistance. Looks like it's open.
This was actually quite a thrill for me. Up to now I've known just enough to read a schematic and follow the instructions, but with this I'm finally getting a grasp on understanding the components and what they should be doing, and I owe it all to you folks who have helped me and helped me learn!
So my next question is as far as replacement goes on this pot....the schematic says it's a 3M ohm rated pot, but gives no floor or stop value, so does this mean this pot goes from 0 ohms resistance up to 3M? And if that is the case, for the purpose of testing, would I be safe to bypass this pot altogether, just to see if I've eliminated the problem, or do I still need some kind of resistance in place to "act" like the pot?
Thanks so much all!
BR
PostPosted: Apr Tue 16, 2019 4:24 pm
That may be a 3,000 ohm - I can't recall when they switched from "M" to "K" to signify thousand.
If you find a Philco part number, I can dig through my NOS parts and see if I've got one to compare readings.
Dan
PostPosted: Apr Tue 16, 2019 4:57 pm
Dan that would be a huge help. The part in question is the VR1 (33-5593-3). It's a dual pot that controls height and centering. The heigh pot (the one I'm interested in) is indeed 3 meg, and the adjacent pot (for the center) is 100K.
Dan, are you the same fellow on the Vintage Television Collectors FB page with whom I have corresponded about parts? I've posted there as well about my Philco Predicta.
PostPosted: Apr Tue 16, 2019 6:34 pm
No, I'm not. I may have to visit that site.
I dug around; don't have any of that part number, nor any close matches.
I would temporarily try jumpering in say a 1 meg, just to evaluate the performance, adjust up or down by 500K to see any change.
If it improves, then you can look in earnest for a replacement.
Dan
PostPosted: Apr Wed 17, 2019 2:04 am
If the oscillator isn't running, the tube will turn hard on and pull the plate voltage (pin 6) to near the cathode voltage.
Pulling the tube will stop this from happening and so the plate pin will go up to nearly B+ or B+boost, wherever it's connected.
Since it doesn't, most likely it's a bad resistor in the height control circuit, or the pot itself. Whatever is in between the B+ and the plate, pin 6.
If there is a transformer and it has a winding in the plate circuit, that is a common failure point. Open circuit or breakdown to frame.
PostPosted: Apr Wed 17, 2019 2:38 am
Success! It was the pot. Wired in a similarly rated resistor and got raster! It's not terribly pretty, and I'm not getting any picture or sound, so there are still issues to be sorted, but I'm closer!
PostPosted: Apr Wed 17, 2019 12:31 pm
Now that you have figured out what was causing the squashed raster, how about fixing the picture size to maybe 800 pixels wide?
PostPosted: Apr Wed 17, 2019 2:44 pm
Pretty please?!
PostPosted: Apr Wed 17, 2019 3:26 pm
Sorry I tried but couldn't get it resized. Maybe a mod can edit it?
PostPosted: Apr Wed 17, 2019 3:28 pm
Here's a repost of it. Now you can just delete the earlier image.
PostPosted: Apr Wed 17, 2019 3:53 pm
Thanks! Since I've solved my raster issue I'm going to start a new thread as I begin work on figuring out why I don't have picture or sound. Thanks for all your help!
BR
PostPosted: Apr Wed 17, 2019 4:07 pm
BR
I'd rethink that. It may be best to continue the story on this set's progress. Often later problems relate to work done in earlier stages. That will make this easier to follow along and share help when needed. Maybe just change the topic title to "Predicta 10L43 restoration" or something similar. No need to have multiple threads on one project.
PostPosted: Apr Wed 17, 2019 5:24 pm
There is a rule for this forum that says one thread per set. I am surprised that the moderators have not complained already.
You can change the subject of this thread by editing the subject in the first post.
PostPosted: Apr Wed 17, 2019 5:32 pm
When I made my previous post about not starting a new thread, I didn't realize that there are already more than a half-dozen threads already going on about this one set. Way out of control.
PostPosted: Apr Wed 17, 2019 5:48 pm
Sorry I didn't know.
PostPosted: Apr Tue 23, 2019 4:11 am
Welp I've made further progress, having found a shorted resistor in my tuner, and swapped out the tube diode which was marginal. I now have a good healthy TV snow, which is encouraging, but blast it all, still no picture nor sound, not even static. I shall resume testing things, but boy what a stumper.
I should've listened to that wizened old fellow with the Maine accent, who warned me when I bought this TV, "Some things are better...dead!"
BR
PostPosted: Apr Tue 23, 2019 4:43 am
What are you using to feed a signal to the TV?
PostPosted: Apr Tue 23, 2019 5:17 am
I have a VCR with an adapter, and also a signal generator/calibrator box. Zilch on both.
PostPosted: Apr Tue 23, 2019 6:28 pm
Hmm... Snow but no picture. Either you are somehow not setting the tuner to the same channel as your signal source is on or the oscillator section of the tuner is not working or is not at the right frequency.
PostPosted: Apr Tue 23, 2019 6:47 pm
yeah both signal output devices have options for channels 3 or 4, both of which I've tried, and I've cycled through all the channels on the tuner. I did have to replace multiple resistors on the tuner; one was shorted and several others were out of tolerance. I wonder if that means I'll have to recalibrate?
Post New Topic Post Reply  [ 80 posts ]  Moderators: 7jp4-guy, Mr. Detrola Go to page Previous  1, 2, 3, 4  Next
