It is currently Sep Fri 25, 2020 5:53 am
 Post subject: zenith console tv quit displaying vhf channels
PostPosted: Jul Sat 25, 2020 5:24 pm
this set quit displaying the vhf tuner but still displays the uhf tuner i need help fixing the set
 Post subject: Re: zenith console tv quit displaying vhf channels
PostPosted: Jul Sat 25, 2020 10:13 pm
Do you mean the dial light ? If so on most Zeniths if you pull off
the 2 knobs you can change it. Usually a #159 or #259 bulb surrounded
by a black sleeve. They dont screw in but pull straight out.
If you mean you cant receive VHF ( 2-13) channels its usually a dead
osc in the VHF tuner. The UHF only uses the RF amp & mixer for
UHF so probably they are OK. If its a tube tuner try the mixer/osc tube,
6GJ7 IIRC first.
If you post again please give the chassis number. Its usually on a tag
on the HV box.
73 Zeno 8)
LFOD !
PostPosted: Jul Sat 25, 2020 10:22 pm
this is a tube tuner set and i cant get channels 2-13 the chassis number is 12b14c52
PostPosted: Jul Sun 26, 2020 12:24 am
Agree, try the 6GJ7 first. If it's not that, then you'll need to remove the tuner and visually inspect it.
PostPosted: Jul Sun 26, 2020 1:06 am
First thanks for follow up for chassis number !
You can pull the mix/osc first & spray cleaner in the socket & try that.
If the problem happened over night order a NOS brand name tube.
Ignore tube testers, they dont run tubes at "frequency" so can often lie !
If it were gradual the tuner could be VERY dirty but shaking the selector knob
should make it come & go.
good luck
Zeno 8)
LFOD !
PostPosted: Aug Sat 01, 2020 9:36 pm
It could also be a dead RF amplifier tube, probably a 6HA5.
Post New Topic Post Reply  [ 6 posts ]  Moderators: Mr. Detrola, 7jp4-guy
