It is currently Nov Thu 26, 2020 1:43 pm
 Post subject: Putting the yoke back on the picture tube
PostPosted: Sep Wed 30, 2020 3:00 pm
I'm restoring an old 1956 Admiral tv, i got a replacement crt. I rebuild the yoke cover where the alignment rings sit. I started to put the yoke back on the new crt but it seems very tight. The inside of the yoke is lined with a carboard form. When i took the yoke from the old tube (sometime ago) don't remember being that tight. Is possible that the neck of this crt may be a little bigger that the original (it is the same tube (21ATP4). I don't know how much force i can put on the yoke so is not to damage it, this is the first time that i have changed a crt.
I'm thinking on smearing the inside of the yoke with petroleum jelly, or using WD40.
Any ideas?
I don't have a problem with buying radios, I can stop anytime I want!!!!
 Post subject: Re: Putting the yoke back on the picture tube
PostPosted: Sep Wed 30, 2020 10:52 pm
Don't use any lube.
I think you should be more concerned with the CRT neck that the yoke.
Can you remove the cardboard liner? Sometimes a piece of cardboard is slipped in around the CRT neck after the yoke slides past the CRT base. The base is often the widest part.
PostPosted: Oct Thu 01, 2020 12:50 am
You can try a small size pipe expander. They come in 3 sizes to expand exhaust pipes on cars. They aren't too costly. I've had this problem with a few yokes being to tight on the neck of the tube. They don't need a lot of turns to give it a little extra room due to shrinkage of the yoke over the years (mostly the plastic wrap they used to keep the winding's separated.)
https://www.amazon.ca/Small-Tail-Expand ... B01HLUVHQM
https://www.ebay.com/itm/Small-Tail-pip ... 1794843916
Tony
PostPosted: Oct Thu 01, 2020 1:06 am
Thanks guys, i just push it a little bit harder and passed the bit thicker part of the neck.
Post New Topic Post Reply  [ 4 posts ]  Moderators: Mr. Detrola, 7jp4-guy
Users browsing this forum: decojoe67 and 4 guests
