It is currently Nov Thu 26, 2020 2:11 pm
 Post subject: Philco universal color bar and dot bar generator
PostPosted: Oct Fri 09, 2020 1:21 am
Useful ? or just obsolete. Only about $30. usd.
https://www.facebook.com/marketplace/it ... 1292753064
119593658_10221740035983969_7599813061566713310_o.jpg [ 202.63 KiB | Viewed 281 times ]
Gary
Semper ubi sub ubi
 Post subject: Re: Philco universal color bar and dot bar generator
PostPosted: Oct Fri 09, 2020 4:52 am
TV pattern generators are useful. More important for color sets than B/W.
I think you might be able to find a more recently made solid state version for about the same amount. Less need to fix it first. Personally I have come to the conclusion that for test equipment that I want to rely on, solid state is less trouble.
Now if you enjoy restoring test equipment then get what ever you want.
Check and see if you can find service info on it since you will have to re-cap it at least and then maybe adjust it before you could use it.
PostPosted: Oct Fri 09, 2020 3:11 pm
Thanks for your opinion. I will give it a pass.
Gary
Semper ubi sub ubi
PostPosted: Oct Fri 09, 2020 4:08 pm
Sometimes tube color bar generators are worth more than their asking price in the 12AX7s they contain.
If you collect color sets from the first couple of years some factory adjustment literature calls out specific generators that produce specific odd ball test patterns that predate standardization and having the correct make/model generator specified is essential for preforming the procedure.
Color sets made after 1960, a small solid state generator and or a test pattern DVD will work fine.
PostPosted: Oct Sat 10, 2020 3:48 am
I still have an early Heathkit generator, and a B&K "Color Analyst" stashed away .
Post New Topic Post Reply  [ 5 posts ]  Moderators: Mr. Detrola, 7jp4-guy
Users browsing this forum: Todd and 12 guests
