It is currently Oct Sat 16, 2021 2:56 am
Post New Topic Post Reply  [ 37 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rough but complete Zenith L2150 luggage portable
PostPosted: Aug Sat 07, 2021 4:34 pm
I got the protection lense reinstalled. It's the first one I have attempted. I guess it looks ok. Got get it installed in the set and fired up to see how bad my attempt was.
Andy
PostPosted: Aug Sat 07, 2021 4:48 pm
Looks great from here!
PostPosted: Aug Wed 11, 2021 2:05 am
I put the tv back together to protect the CRT and gave the tv a quick bath. I won't be back on this for a while but I did enjoy the CRT fix.I have to find a picture of what tat front panel looked like.
Andy
PostPosted: Aug Wed 11, 2021 7:04 pm
Before I pt this one on the to do shelf. I decided to do a quick power up. I fired it up on my variac and it fired up without letting any smoke out. It was drawing 1.27a at 120V and has a raster. The picture looks worse than I cant see in person. Its just a solid white picture to me. It has issues like but looks to be fixable. I found an image of like model that I can use to figure out what to do with the panel above the CRT.
This is what the panel should look like
Andy
PostPosted: Aug Thu 12, 2021 4:05 am
Way to go for restoring such a set. Not many people would do such a thing. You and me are some of the last.
Electronics are filled with smoke. Itā€™s my job to put the smoke back in when they fail.
Cheers,
Jay
PostPosted: Aug Thu 12, 2021 5:34 pm
Looks like there are 2 problems: the vertical isn't filling the screen (the cathode lytic on the vertical output is a likely cause), and there's no signal which could be a dirty tuner bad tube or no signal source in the last picture...
PostPosted: Aug Thu 12, 2021 8:29 pm
I agree on the vertical. I did not have a signal injected so the non picture was expected.
Andy
PostPosted: Aug Tue 24, 2021 3:19 pm
No good deed goes unpunished. I had a few minutes and decided to replace the electrolytic the vert section as mentioned previously and while I was at it I did a little tube jack cleaning and pot deoxiting. I finished those 2 task and fired up he set and was greeted with no raster an tube filaments off. I started doing some checking and some how I managed to do this.
Now I am waiting on a replacement to arrive. No idea how I did this but I am sure Drop Dead Fred was had something to do with it.
Andy
PostPosted: Aug Tue 24, 2021 4:22 pm
Don't beat yourself up over that tube. Cracking around the bases of those horizontal output tubes is not unusual, doesn't take much to finish them off when turned back on after a long time.
PostPosted: Aug Tue 24, 2021 7:34 pm
Had that happen to me on the $25 6LQ6 in my CTC25 a couple weeks ago...the pins had corroded a bit and between that and heat cycling the envelope cracked...It went down to air while running so I got to watch the raster shrink, go dark and the damper start to redplate as the base of the output started glowing blue/purple and sparking. It's not super common but it happens.
PostPosted: Sep Wed 08, 2021 1:25 am
I am finally back at home and got a chance to install the 17gv5 and powered the set up and got, notta. I realized the filaments were not lit up and started a search for another bad tube or at least connection for a tube. The set was drawing about 300ma. I discovered that the 6ae8 in the tuner (it is completely shielded) had also gone to air. What ever took out the 17gv5 also went after the 6ae8. I was able to find a 6gh8a to replace it. I brought the set up on my variac and we have a raster again and the vertical issue is much better with the replaced electrolytic. If I have time tomorrow Ill see if I can get a picture and sound (there is sound, just static).
PostPosted: Sep Wed 08, 2021 8:20 am
In the late 60's GE used to make B&W portables locally (in Australia) using Compactrons. The service company I worked for did warrant service on them. We saw a batch of tube sockets that were made from a type of plastic that would shrink with heat, crunch the tube pins and crack the glass, especially on the 38HE7 hor OP - Damper tube. Diabolical!
PostPosted: Sep Wed 08, 2021 1:03 pm
Manufacturing/production choices and there impact on MTBF can be clearly seen here.
PostPosted: Sep Wed 08, 2021 6:05 pm
I know have picture and sound.
Andy
PostPosted: Sep Thu 09, 2021 7:54 pm
Andy
Looks like all it needs is adjustment of the height, vertical linearity and possibly centering.
If you don't have a test pattern generator get a DVD movie with end credits that have even spacing between lines of text when viewed on a different set, pause the DVD and adjust height and linearity to even out spacing on your TV. Another thing you could use instead of end credits is a close up of a circular object like a clock, the sun or a wheel and adjust set for roundness.
PostPosted: Sep Fri 10, 2021 10:46 am
A better idea is to use a real test card, stored on a USB stick and displayed by the slide viewer feature of your media player.
There's a good one in this post, the Philips PM5544 test card stretched so that it displays properly in 4:3.
viewtopic.php?f=3&t=378196&p=3326631&hilit=PM5544#p3326631
That is a RARE flyback I managed to find for this guy! I hope I never need one myself!
I'll paste it here as well. You can right-click it and select Save Image As
Yes this is a PAL test card but it will work just as well on US EIA / NTSC 525 lines and display with the correct aspect ratio.
PostPosted: Sep Fri 10, 2021 8:48 pm
Here it is hooked up to my 1077b.
Eek! No knob turning made it better than this. All I've done electically is replace 2 tubes and 1 cap. Lots more to go thru here.
Andy
Post New Topic Post Reply  [ 37 posts ]  Moderators: Mr. Detrola, 7jp4-guy Go to page Previous  1, 2
