Page 1 of 1
[ 5 posts ] |
Author |
Mr. Highlander
Post subject: General Electric 821 Chassis Horizontal linerity issue Posted: Jun Fri 24, 2022 2:15 am |
Member |
Joined: Mar Sun 22, 2020 4:56 am Posts: 2112 Location: Arvada, CO, 80004
Top |
ACORNVALVE
Post subject: Re: General Electric 821 Chassis Horizontal linerity issue Posted: Jun Fri 24, 2022 3:19 am |
Joined: Jan Wed 15, 2020 11:29 pm Posts: 2170 Location: AUSTRALIA
Generally stretching on the left side is due to insufficient damping, a low emission damper diode can do it.
The drive wave to the output tube g1 grid has some effects on the linearity, but only about the right hand 2/3 of the scan and as you know if the drive is too high, it can put a fold over on the current when the plate current starts and you can get that vertical white line effect (that is the beam tracing back on itself a few times).Your measured drive waveform doesn't appear to match the schematic so you may want to check into that.
The left hand 1/3 of the scan is due to damped current. In tube sets, the linearity was generally adjusted with a series resonant circuit which modulated the supply voltage of the plate primary circuit with a parabolic like wave, just off the side of the circuit you posted, where C322 is, is the modulation voltage applied to the LOPT primary, you could check that on the scope, but generally this had fairly minimal effects on the left sided linearity, it largely affects the center, but if that L-C network is off it can affect the linearity elsewhere.
Top |
Mr. Highlander
Post subject: Re: General Electric 821 Chassis Horizontal linerity issue Posted: Jun Fri 24, 2022 3:47 am |
Member |
Thank you! I has going to do a ringing test on the flyback/yoke. I did not know that a weak damper tube could cause that. And yes, They signal looks nothing like what it should. However, in other schematics, it looks normal. I has going to feed a horizontal signal, just to check it out as well. I was debating on whether the signal or the yoke/flyback LC network was off.
And for the schematic, that one was off a GE 805 from Rider, which uses a similar chassis to the 821. Here is the Sams of the Horizontal for that.
Attachments: |
_________________ Electronics are filled with smoke. It’s my job to put the smoke back in when they fail. Cheers, Jay
Top |
irob2345
Post subject: Re: General Electric 821 Chassis Horizontal linerity issue Posted: Jun Sat 25, 2022 1:28 am |
Once you set the Hor Drive to just eliminate the drive line, the drive waveform has little effect on the linearity.
A good starting point is to monitor the hor OP tube cathode voltage (if it has a resistor in it) and adjust the hor linearity coil for minimum current. That will generally get you close to best linearity, a small tweak either side of the minimum voltage (and hence current) point will generally be all you need. Try not to go over about 10% of minimum.
Doing it this way gives best hor op tube and flyback life.
If you then need to adjust the width, go back and check the linearity again. Width will also affect the tube current.
Oh yes. If there is a cathode resistor it will be bypassed with a capacitor. Unless it's a film cap, replace it.
_________________ Wax, paper, bitumen, cotton, high voltages - what could possibly go wrong?
Top |
ACORNVALVE
Post subject: Re: General Electric 821 Chassis Horizontal linerity issue Posted: Jun Sat 25, 2022 5:19 am |
Mr. Highlander wrote: They signal looks nothing like what it should. However, in other schematics, it looks normal. The signal you measured on the scope has basically the correct form to be a good grid drive for a horizontal output tube. It is a trapezoidal shape which is a mixture of a sawtooth (during scan time) and a rectangular wave(during flyback). The idea being that the grid gets taken very negative at flyback to ensure the tube is properly cut off. Normally this wave is created by placing a resistor of a typical value around 4.7k to 10k in series with the sawtooth forming capacitor. Part R99 on the last circuit you posted. It goes by the name "peaking resistor".
Top |
Who is online |
Users browsing this forum: No registered users and 13 guests |
