How is a tv tuner taken out when the channel label obstructs
Share collecting tips/ideas, discuss antique televisions and related items. Ads are not permitted.
Moderators: Mr. Detrola, 7jp4-guy
Post Reply
67hjn
Nov Sun 28, 2021 7:56 am
Rittman, Ohio
Post by 67hjn »
This is a goldstar 1983 tv with knobs. The VHF portions has plastic which keeps from being able to detach the tuner from the plastic frame. The only way around seems to pry the knobs off which will probably break something
zeno
Apr Sat 06, 2013 1:18 pm
Mason, New Hampshire
Re: How is a tv tuner taken out when the channel label obstr
Post by zeno »
Carefully pry them off. If they got glued on you have a problem !
Zeno
67hjn
Rittman, Ohio
Post by 67hjn »
zeno wrote:Carefully pry them off. If they got glued on you have a problem !
Zeno
I was able to do this for the VHF knob IIRC. For the UHF knob it was harder and IIRC I did not try further to avoid damage
irob2345
May Sun 07, 2017 10:35 am
Belrose, NSW, Australia
Post by irob2345 »
Use two metal shoe horns, one either side of the knob, and lever it off, keeping it parallel with the case.
The finger hook ends go under the knob.
Electronic Memory
Nov Thu 11, 2010 5:03 pm
Pewaukee, WI
Post by Electronic Memory »
Another option if you are having trouble getting a purchase on a knob is to loop the edge of a T-shirt under the back edge of the knob and use it as a handle to apply more force.
You must be register and login to post a reply.
Post Reply
