It is currently Aug Fri 23, 2019 3:24 pm
 Post subject: Zenith 3000-1 AC Adapter
PostPosted: Jun Wed 12, 2019 3:01 pm
Does anyone have experience with the AC adapter on eBay. Says regulated 12V with something called ICL. Looks good and has all positive feedback. $24 shipped but takes offers.. :roll:
 Post subject: Re: Zenith 3000-1 AC Adapter
PostPosted: Jun Wed 12, 2019 5:05 pm
I have no specific information about this adapter but the general requirements for the power supply are extremely undemanding, only about 20-25 mA at 11-12.5V. Almost anything with a regulated 12V output would work if you get the polarity on the plug the right way around. I think I got mine for about $1.75 from at Halted electronics, they had a huge box of them. I cut the wire, flipped the polarity around, and spliced it back, works fine.
Many unregulated "12V" wall-warts will float to higher voltages when presented with the very low current draw of the radio, since they depend on the load depressing the voltage, so maybe a 9V 100 mA wall war will float up to 12V under 20 mA. I don't see any good way of telling how that will work for any particular supply. I would just get a regulated type, they are cheap - much cheaper than $24!
The polarity is critical, however. It's opposite from almost any modern adaptor, the center pin is NEGATIVE and the ring/shield is POSITIVE.
By the way, I have both an original Zenith wall-wart (that looks like something rejected by the Russian Army) and the cheapie I mentioned. I almost never use them, 8 D alkaline batteries last an eternity.
Brett
PostPosted: Jun Wed 12, 2019 9:03 pm
Just use batteries, they will last for years.
viewtopic.php?f=4&t=349144
PostPosted: Jun Thu 13, 2019 1:26 am
Just measure the prospective wallwart's unloaded voltage with your DMM. As noted, most cheapy 9v types will run around 12v unloaded, so they would work fine. The deal is, the Zenith's Germanium transistors don't cotton to getting much over 12v. What with the radio's legendary miserly battery-draw, it's all too easy to overvolt it. That's the primary power supply issue.
So far as powering off batteries, I just stubbed in a 9v connector and use a lightweight 9v Alkaline. The 3000 works just as well with those and is much lighter/cheaper than installing 8 D-cells. Besides, when going mobile with it, it saves the weight stress to the flimsy Antenna/handle! If it's your daily driver for several hours per day, then it would make sense to pop for the bulkier D-cells or go 9v wallwart.
-Ed
I'd gladly pay you next Tuesday for a radio today!
PostPosted: Jun Thu 13, 2019 1:09 pm
-Ed
Thanks for the info and I hear ya. I've noticed no load voltage on old school transformer type 9V wallwarts ranges from about 13.5 to around 15V. A small load brings it down to around 12 and ofcourse rated load to around 9. I actually use old 9V blocks as float chargers on a couple seasonal cars I own. Works fine..as battery voltage drops wallwart current inherently increases maintaining 12.5-13V...not sure I want all this variability for my poor old transistor TO but I appreciate the insights..
PostPosted: Jun Fri 14, 2019 5:25 am
1R5X50 wrote:
-Ed
https://www.amazon.com/lm7812-voltage-r ... +regulator - ~40 cents.
Brett
PostPosted: Jun Fri 14, 2019 1:22 pm
dont forget the caps from g to in and g to out.
i usually use 10uf 25v tantalums.
without these it may oscillate!
Post New Topic Post Reply  [ 7 posts ]  Moderator: Dave Doughty
