Page 1 of 1
[ 11 posts ] |
Author |
1N770
Post subject: Sears Silvertone 132-31001 AC Transistor Radio from 1968 Posted: May Mon 16, 2022 10:14 pm |
Member |
Joined: Aug Mon 16, 2021 3:25 am Posts: 246 Location: Lewis & Clark Stomping Grounds, Oregon, USA
A very unusual Sears Silvertone (57H 8022) AC - powered AM/FM Stereophonic Transistor Radio.
Well, I saved this one from the landfill. It was quite dirty and dusty when I got it but it cleaned up well. I opened up the back to inspect the chassis before attempting to power it up and was met with lots of dust and spider webs! Cleaned up the chassis and hit the variable capacitor with some compressed air. Lubricated all the dial string pulleys and some DeOxit on the v. cap rotor brushes.
This radio is close to impossible to service! With service, I mean the basic stuff like replacing electrolytic capacitors, cleaning switches and potentiometers. Very odd layout. When the back cover comes off, the solder/trace side of a large vertical PCB faces you. Components are only visible if you remove chassis. With chassis out, you find 4-5 individual small PCB's soldered horizontally to the large vertical PCB. These smaller PCB's are jam packed with components (transistors, resistors, capacitors, diodes, etc.) and several tabs go through slots on the main board and are soldered. Also, many wires running to these smaller PCBs. The larger components like transformers and coils are on the main board. In order to re-cap the many E.C's, each small PCB would need to come off the main board and multiple wires removed. To top it off, all of the pots for volume, treble, bass, balance & band switch are not accessible to inject DeOxit.....each pot is mounted on a small PCB that blocks access.
This radio would be a radio repairman's worst nightmare. Probably one of the most labor intensive restoration projects I've seen for a simple re-cap. I figured if it works well, job done. If not, well I guess back to the final destination - landfill.
Slowly powered up a a variac and it came to life. A little scratchy on the volume pot when adjusting volume but otherwise sounds great with no issues. It has a unique dial light that backlights the dial with a "blue glow" - similar to a car instrument dashboard light at night. It isn't a lamp, but a rectangular plate that is white in appearance when radio is off (possibly glass?). It has AM-STEREO-FM indicator lamps, FM AFC, tuned RF, bass, treble & balance. Two 4 X 6 oval speakers and option for external speakers. 16 transistors and an IC (somewhere on the PCB ?) Unusual size - 22.25" X 9.3" X 4.75"
Very little info on this one. Found some info on Radiomuseum and in the 1968/69 Sears Catalog. Model is "57H 8022". Might be manufactured by Warwick for Sears Silvertone brand. I would love to see a schematic on this but I have found nothing. Possibly no schematic out there.
Anyone familiar with this radio? Any leads on finding a schematic?
UPDATE: Radio Model "57H 8022" as shown in 1968-1969 Sears Roebuck Catalog has the chassis # 132.31001. Manufacturer of this radio for Sears was Arvin (132).
Jeff
Attachments: |
Top |
35Z5
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Mon 16, 2022 11:06 pm |
Member |
I doesn't have a three digit mfgr code?? If Warwick, 99.9% there would be a schematic & mfgr code... In late '60s Warwick, plus Arvin, Sanyo & Toshiba were major electronic suppliers.
_________________ Tom
Top |
1N770
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Mon 16, 2022 11:28 pm |
Member |
35Z5 wrote: I doesn't have a three digit mfgr code?? If Warwick, 99.9% there would be a schematic & mfgr code... In late '60s Warwick, plus Arvin, Sanyo & Toshiba were major electronic suppliers. There is nothing on or in this radio that documents anything. Maybe there was a paper label glued on the bottom that fell off over the years. The cabinet is made of wood (particle board) and plastic. Particle board expands a little in humid conditions and I can see a paper label not sticking well to it. I got "57H 8022" from the description in the 1968 & 1969 Sears catalog. I see no three number manufacturer's code anywhere. From what I have researched, the likely manufacturer is Warwick or Arvin. Most of the electrolytic capacitors are Japanese-made "ELNA" brand along with Hitachi germanium transistors. Maybe a Japanese provider but I think even US manufacturers were using Japanese parts by the late 60's. Jeff
Top |
Ed in SoDak
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Tue 17, 2022 1:01 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5777 Location: Black Hills, SD 57745
Look on the right bottom rear. Below and left of the AC plug and right of the Sears name.
_________________ My life is loosely based on a true story.
Top |
1N770
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Tue 17, 2022 1:21 am |
Member |
Ed in SoDak wrote: Look on the right bottom rear. Below and left of the AC plug and right of the Sears name. Yes. I probably should have mentioned it but I saw no connection to a valid manufacture code or model #. The number located left of AC cord and right of Sears name is: 2002892 Still confused. There were too many secret codes in the Sears Roebuck empire, lol. Jeff
Top |
35Z5
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Tue 17, 2022 2:16 pm |
Member |
In addition to labels on cabinet, they were affixed to chassis as well. Methode was Warwick's supplier for PCB, EIA code(720 I believe)often etched on the boards. They have a distinct look, early GE also used Methode boards. AFAIK Arvin built their own boards. Methode boards. viewtopic.php?f=4&t=346815
Top |
1N770
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Tue 17, 2022 3:53 pm |
Member |
Thanks Tom! I will look at the PCB's for any clues. Interesting that the Methode Corporation stills exists today and produces products for the automotive, industrial and medical industries. Company history on their website states that they were pioneers (1951) in printed circuit technology. ( www.methode.com) Jeff
Top |
1N770
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Tue 17, 2022 10:35 pm |
Member |
Top |
35Z5
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Tue 17, 2022 11:46 pm |
Member |
132, its Arvin.
Top |
1N770
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Wed 18, 2022 12:51 am |
Member |
35Z5 wrote: 132, its Arvin. Yes! 132 - Noblitt-Sparks (pre-1950), Arvin (post-1950). Thanks Tom. Kind of ridiculous that the chassis # is found on a tiny aluminum tab requiring chassis removal from cabinet and a magnifying glass! Radio working very well so won't fix what isn't broken. Yet....... Jeff
Top |
35Z5
Post subject: Re: Sears Silvertone 57H 8022 AC Transistor Radio from 1968 Posted: May Thu 19, 2022 4:14 pm |
Member |
Both Arvin & Warwick used the small metal tags.
Here's a 1962 Silvertone 2206 built bt Arvin, uses the round finger size 9v battery(pictured with AA).
Attachments: |
Top |
Page 1 of 1
[ 11 posts ] |
Users browsing this forum: plronbio650 and 10 guests |
