Good evening!
I could use a hand with this one.
We have a VEF Tranzistors radio that has only light static across all bands or dial positions. Also, the volume control has no effect.
https://www.radiomuseum.org/r/vef_vef_t ... xport.htmlDoes anyone know if VEF ever supplied a board layout diagram for this model? I don't mind working it out from the schematic, but the diagram sure would save on time.
So, I started with the electrolytic caps; some have very high ESR or test open (lifted one leg). These are odd caps. According to the schematic, they only list the capacitance, not the voltage. I was planning on sticking to the original uf value and at around 25V for derating. Does that sound acceptable?
Next, the transistors appear to be germanium
PNP type and OEM replacements seem quite rare. Based on the schematic, are there any good substitutions? 9/10 check OK, and 10 lost it's legs due to corrosion. I attempted to solder a single strand of copper wire to the nibs, but it isn't having it! I'll have to replace at least that one, but figured I would order more while I'm at it. Just need to figure out the cross reference...
Very tempted to finally order an Atlas DCA55!
The remaining board components I think I'll leave alone for time being.
Very cool little unit, would love to see it working again. Any assistance is appreciated!
Edit: Transistors are PNP type
