It is currently Nov Sat 26, 2022 4:19 pm
 Post subject: Great article on Transistor Transoceanics raises a question
PostPosted: Nov Wed 23, 2022 4:00 am
"The 7000Y was followed by the Royal 7000Y-1 in 1971, which uses chassis 18ZT40Z, and in 1972 by the Royal D7000Y, with chassis 500MD70. Although the circuits are very similar, different transistors are used in the various chassis, but the primary difference is in the VHF weather channel. The Royal 7000Y only offered 162.55mHz coverage. The Royal 7000Y-1 had a provision to change the crystal controlled VHF frequency, and the Royal D7000Y had continuous tuning of the weather band. The D7000Y is the more popular model due to the tunable weather band, and the inside of the front lid, with the compass, was changed from grey to black, a more attractive combination."
http://elmphotography.com/radios/radio31.htm
Just checked mine, it is the Royal 7000Y-1, chassis #18ZT40ZE
(Anyone know what the E letter means?), and according to the article, has a "provision to change the crystal".
The present crystal is for the stock 162.55 Mhz.
My local weather is 162.400 Mhz...
I'm hearing nothing on the stock 162.55 Mhz. crystal.
Are different crystals still available anywhere for these sets?
My example is in beautiful condition, not to be OCD, but it would be cool to have the weather band work here.
This is the set playing - love the sound of American craftsmanship!
https://youtube.com/shorts/iUUi-UCeIns?feature=share
"Invisible airwaves crackle with life
Bright antenna bristle with the energy"
 Post subject: Re: Great article on Transistor Transoceanics raises a quest
PostPosted: Nov Wed 23, 2022 5:10 am
I've never heard of a chassis 18ZT40ZE
Padgett Peterson's archived web-pages.
https://web.archive.org/web/20060715011 ... tohome.htm
That elmphotography page was written by Ed Morris, a member here... :)
PostPosted: Nov Wed 23, 2022 7:03 am
Thank you, egg!
You are correct, there is no "E" suffix.
It does look like there is a "3" suffix.
Looks like the original earphones were never opened! :lol:
PostPosted: Nov Wed 23, 2022 7:17 am
Just looked at the information you so kindly provided.
The "3" suffix tells me my set is the Royal 7000, not the 7000-1 which came later.
I am still in love with this set, thanks for clearing things up for me!
PostPosted: Nov Thu 24, 2022 6:59 am
The problem with crystals is demand has mostly dried up. Fifty years ago, you had little choice. Butas synthesizers moved in, demand dropped drastically. Every two way radio needed two crystals per radio.
Every scanner needed one crystal per channel. CB sets needed two crystals per channel, exceptfor the ones that used fewer and mixed the output together. Most of the crystals today are made for standard frequencies. Custom ground crystals are really expensive, and few places do it.
The problem is accentuated by the fact that many crystals aren't interchangeable. They have to fit the radio. The actual frequency variesby the intermediate frequency the radio uses, and how itgets to that frequency.
Your real hope is to find someone selling a crystal for the Transoceanic for the right frequency. Given the age, it may have been before there was more than one Weather radio frequency.
I bought a pair of used FRS walkie talkies to play with, discovered they tuned all the Weather channels. So does my Baofeng walkie talkie.
PostPosted: Nov Thu 24, 2022 7:41 am
You could look into grinding your own crystal to suit, bit of an art as I understand it.
Another day older and deeper in debt.
PostPosted: Nov Thu 24, 2022 7:58 am
You can only easily grind crystals that are old enough to havescrews to open the case. The metal cased ones, as used in the Transoceanic are much harder to grind.
Grinding moves crystals up. But it's really meant for a slight adjustment. Soyou need a crystal close to the desired frequency, but lower.
PostPosted: Nov Thu 24, 2022 2:28 pm
You might be able to feed the crystal oscillator from one of the new-fangled programmable oscillator chips, pre-programmed to the right frequency. You’d probably want an attenuator between the chip output and the crystal input, and capacitive coupling to avoid upsetting the bias on the oscillator.
PostPosted: Nov Thu 24, 2022 4:11 pm
Some good information in this thread as to the actual crystal frequency needed --
https://antiqueradios.com/forums/viewto ... 4&t=358494
- Jim
PostPosted: Nov Thu 24, 2022 11:11 pm
Thanks, mblack!
For a few years, I worked at a company in Erie Pa. "Bliley Eleectric".
My job - grinding crystals on Blanchard grinder for the U.S. Army Signal Corps!
:lol:
PostPosted: Nov Thu 24, 2022 11:14 pm
It is indeed an art.
It was, at one time, my job.
The volume we put out required heavy industrial equipment.
PostPosted: Nov Thu 24, 2022 11:16 pm
That is interesting!
First I have heard of these chips, thank you!
Users browsing this forum: Blustar1, lorenz200w and 6 guests
