It is currently Jan Sat 18, 2020 10:54 am
 Post subject: Channel master 6515
PostPosted: Nov Sat 24, 2018 1:19 pm
I just finished recapping this radio and it plays good but the volume control is scratchy. How do I clean this control ? I'm used to working on tube radios with a metal volume control so this is something new.
 Post subject: Re: Channel master 6515
PostPosted: Nov Sat 24, 2018 4:50 pm
I clean controls just as if they were in a tube radio. Many are semi-sealed, working cleaner in around shaft in rear of control that operates the switch seems to give best results. Access is usually biggest problem.
PostPosted: Nov Sat 24, 2018 8:33 pm
That worked good, the scratching sound is gone. This radio picks up stations that I’ve never heard before. I have steel siding on my house but that doesn’t seem to matter to this radio!
PostPosted: Nov Sun 25, 2018 5:52 am
The 6515 “Super Fringe” is noted for its ability to pull in distant stations, and it’s a good looking radio, too. The Channel Master transistor radios were made in Japan by Sanyo.
Ed
PostPosted: Nov Sun 25, 2018 5:45 pm
Glad you have it working well !
They are excellent radios and as Ed said, good looking too...
PostPosted: Nov Sun 25, 2018 8:41 pm
I have one. They are more like a small table set than a pocket portable, and the dial looks like the face of a clock, sorta. The four Transistors in the RF stage, including the RF amp, and the four in the audio stage, along with the lengthy antenna ferrite core, make for a good DX machine!
PostPosted: Nov Fri 30, 2018 1:02 am
Great audio tone is my favorite feature of the 6515. It's my go-to set these days. All I had to do with mine was tweak the trimmers and clean the volume. It's working fine with original caps, nothing at all has been replaced, though the tuning cap is scratchy. Not a huge issue as I mostly use it to listen to just a few local stations or my transmitters, all of which reside on the upper half of the dial where it's not noisy.
I use still-serviceable nicads salvaged from failed drill-driver battery packs for power. They'll run it a month or two between recharges. Too bad the 6515's case is so often cracked, chipped or has a dented grille. Mine is no exception. It's a user set, not a collectible. Which suits me fine!
-Ed
PostPosted: Dec Wed 05, 2018 5:54 am
In the beggining my radio had a normal sensitivity so I changed all electrolytic capacitors and noted an improvement in reception so good that I went ahead and changed ALL capacitors and then the radio became extremely hot like not other radio I've seen before, inclusive better than my Panasonic RF2200.
After changing all capacitors it was neccesary to align ,again, all the IF transformers, making them "peaky"
I strongly recommend changing ALL capacitors.
PostPosted: Dec Sat 08, 2018 3:46 am
I replaced all 10 caps in this radio and it really woke up. I’m picking up a few stations that my GE superadio 2 barely receives. There appears to be a station at nearly every position on the dial!
PostPosted: Dec Sat 08, 2018 5:53 am
The gray or orange plastic Japanese electrolytics are almost always bad, and have a much higher failure rate than US capacitors of the same era.
I am very happy with my 6515, it's a very high quality product with outstanding performance, and not nearly the pain in the rear end that some of it's Japanese compatriots to work on.
Brett
PostPosted: Apr Wed 03, 2019 4:07 am
I've got a 6515 headed my way! :) All the links to schematics I've come across are broken. Can any of you guys point me towards a schematic?
Brian
PostPosted: Apr Wed 03, 2019 4:46 am
You don't need the print in order to swap out the Electrolytics, but if you run into trouble, PM your email addy, and I'll send it to ya.
PostPosted: Apr Wed 03, 2019 5:05 am
Ok, thanks fifties!
PostPosted: Apr Wed 03, 2019 2:14 pm
Brian
I've got some of the Sams here: https://www.dropbox.com/sh/dhpmmpgjxo3i ... xOrua?dl=0
PostPosted: Apr Wed 03, 2019 2:25 pm
Beautiful! Thank you very much!
Brian
PostPosted: Apr Wed 03, 2019 6:28 pm
Best bang for the buck next to the GE Superadio for performance. :)
PostPosted: Apr Wed 03, 2019 7:37 pm
Nice! Well, this was given to me but I paid the $13 shipping plus $10 for his trouble. He said it turns on but doesn’t have any output so I’m looking forward to getting a project soon!
PostPosted: Apr Wed 03, 2019 7:55 pm
Most likely simply changing the 4 E-caps should get it singing again.
PostPosted: Apr Wed 03, 2019 8:51 pm
Yes, that’s what I’m getting from the many threads I’ve found on the subject. I’ve got them all in stock. It’s going to be the first go for the homemade ESR meter (Alan Wolke spec) I just made:
File comment: ESR Meter
PostPosted: Apr Thu 04, 2019 2:34 am
As you've heard, they're excellent radios...
Looking forward to your ESR report on the many electrolytics !
Post New Topic Post Reply  [ 33 posts ]  Moderator: Dave Doughty Go to page 1, 2  Next
