It is currently Feb Fri 21, 2020 5:57 am
Post New Topic Post Reply  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: Channel master 6515
PostPosted: Apr Thu 04, 2019 5:11 am
Received the radio this afternoon. Even came with new batteries.
It's all done. About an hour on the operating table. 10 e-caps replaced. Started out with nothing more than a steady 'hiss'. Progressed to full rich fidelity and excellent sensitivity after the job was done. I checked operation as I went along and it kept improving steadily after each cap was replaced.
I'll check the old caps on the ESR meter tomorrow and report back.
Brian
File comment: Received the radio today:
File comment: Opened it up. 10 electrolytics to replace:
File comment: All finished. Sounds great!
PostPosted: Apr Thu 04, 2019 6:22 am
Good job!
PostPosted: Apr Thu 04, 2019 3:14 pm
Thumbs Up!
Most of those caps are no doubt dried out due to case cracking or epoxy seal failing.
PostPosted: Apr Thu 04, 2019 4:45 pm
Ed Morris did a fantastic job some years back, by restuffing all the original Sanyo capacitors in one of his radios. Unfortunately his images are no longer available!
:) Greg.
PostPosted: Apr Thu 04, 2019 5:06 pm
Thanks fifties, Tom!
Greg, I likely ran across some of those posts as I was researching this repair. There were many from years back with broken image links. :cry:
Working on old cap testing as I type this...
Brian
PostPosted: Apr Thu 04, 2019 5:15 pm
I think Ed drilled them out with a flat bottom drill-bit. I have a few of those Channel Master radios and also some of the Sanyo versions... but, they are all happily running on their original caps... go figure!
:) Greg.
PostPosted: Apr Thu 04, 2019 6:39 pm
Yes, they are nice little potted type caps that would lend themselves well to 'restuffing'. Me? I wouldn't have the patience for it, though. :)
PostPosted: Apr Thu 04, 2019 8:07 pm
I tested the original capacitors removed and the replacement capacitors with the three different testers that I had available. Here's the results of the tests:
PostPosted: Apr Thu 04, 2019 8:19 pm
I'm sorry; we need something more thorough than that.
:wink:
PostPosted: Apr Thu 04, 2019 9:29 pm
Blast,
Great Channel Master and a thorough recap.
I wonder if we can get a summary report then follow up with a redacted full version. OK I admit that was uncalled for.
Seriously, the greatest challenge I had with recapping old transistor radios was keeping polarities correct since the polarity marking conventions of that time were inconsistent. I've had some marked at positive lead, others negative, and others not at all. To add to the confusion is the typical positive ground used with the PNP transistors.
PostPosted: Apr Thu 04, 2019 11:10 pm
fifties wrote:
I'm sorry; we need something more thorough than that. :wink:
:lol:
There was NO collusion with Panasonic! :)
Tkilboy wrote:
...keeping polarities correct...
Yes, and that's why i do my best to find a schematic to whatever I'm working on before I start. It helps me to understand the circuit which helps me minimize errors. And, since the dawn of digital photography I take a LOT of photos of what I'm working on, as well.
I really haven't done any serious DX'ing on this yet but I was pulling in Topeka (60 mi.) and Nashville (550 mi) stations with ease last night and today. And, it may not be the BEST fidelity I've ever heard in similar sized radios... but the audio quality IS top notch!
Brian
PostPosted: Apr Fri 05, 2019 1:32 am
I've never owned a ESR meter, reversing polarity while using a analog meter has always been enough for me. If cap has at least some capacatance, needle will jump to swing depending on value. No movement equal open cap.
PostPosted: Apr Fri 05, 2019 1:57 am
Nor had I. At least, until I saw Alan Wolke's ESR meter video: https://www.youtube.com/watch?v=bmYAgat-sOQ&t=170s
The project looked so interesting and I had most of the components laying around (including a millivolt HVAC repair meter that I knew I would never use for its intended purpose) so I just decided one day to whip one up.
Post New Topic Post Reply  [ 33 posts ]  Moderator: Dave Doughty Go to page Previous  1, 2
