It is currently Jul Thu 18, 2019 8:25 am
 Post subject: Selga 7 Transistor radio coil leads resoldering help
PostPosted: Apr Thu 11, 2019 8:36 am
Hi,
My name is Peter, i have recently received a used ,non functional Selga 7 transistor radio from probably 1963 or 1964 and my big problem is ,that more than one leads of the coils found on both sides of the ferrite have broken off the PCB and i cant determine which one gets soldered where.The radio was in bad shape with the ferrite broken in two , but i fixed that part with glue.
My question is ,could somebody send me some pictures of this particular models coil leads, where you can clearly see which leads becomes soldered where.I would appreciate it.
I have also attached a front picture of my Selga radio.
Thanks in advance ,
Peter
 Post subject: Re: Selga 7 Transistor radio coil leads resoldering help
PostPosted: Apr Thu 11, 2019 10:51 am
Hello Peter, here you go:
PostPosted: Apr Thu 11, 2019 8:34 pm
Thanks for the schematic, but the problem is that i have 6 leads on one of the coils, but this drawing only shows 4 coil connections .So how do I wire them correctly ? I have also attached a picture of what I am talking about.
PostPosted: Apr Thu 11, 2019 9:07 pm
I hope this helps:
PostPosted: Apr Fri 12, 2019 6:51 am
Hi, petergreenpeace!
I think that these pictures will be helpful for you!
Any questions - you are welcome!
PostPosted: Apr Fri 12, 2019 8:02 am
Thanks for everybody for the schematics and picture, now I can fix the Radio
PostPosted: May Fri 31, 2019 8:09 pm
petergreenpeace
What's news about "Selga"?
PostPosted: Jun Sun 02, 2019 8:00 pm
I have resoldered the wires and changed the electrolytics and it works again.
PostPosted: Jun Sun 02, 2019 10:00 pm
petergreenpeace
OK!
Post New Topic Post Reply  [ 9 posts ]  Moderator: Dave Doughty
