It is currently Jan Sat 18, 2020 6:48 am
 Post subject: Model Number
PostPosted: Jul Wed 31, 2019 7:13 pm
Can anyone tell me the model number of this radio? It is made in Hong Kong. I would like to locate a schematic for it.
Thank you.
Steve
 Post subject: Re: Model Number
PostPosted: Aug Sat 03, 2019 9:23 pm
Steve - There is a photo of your Star Lite 6 transistor radio on page 150 of Norman Smith's book, Transistor Radios 1954 - 1968, but no model is listed, just that the radio was made in Hong Kong in 1965. There is another radio that was made by Star Lite that is similar to your radio and there is information available on the Radio Museum website that you can download:
https://www.radiomuseum.org/r/star_lite_trn_79trn7.html
PostPosted: Aug Sat 03, 2019 9:53 pm
Thank you SO much!
I can now begin to troubleshoot the IF section.
Sincerely;
Steve
PostPosted: Aug Sat 03, 2019 9:58 pm
I have one of those, just with a different badge. What is the problem with yours that you think the IF section is faulty? Usually that's the last circuit to be suspect in these.
PostPosted: Aug Sun 04, 2019 12:59 am
Steve - There was a recent eBay sale of your Star Lite transistor radio and it is a model TRN77 as it is printed on the box:
https://www.ebay.com/itm/Vintage-Star-L ... 7675.l2557
The Star Lite Model TRN77 can also be found on the Radio Museum website, but unfortunately, there is no information on the circuitry, but they do show a photo of the box. - Mark
PostPosted: Aug Sun 04, 2019 1:36 am
This schematic for Rivera model RV62 should be the same.
2SA142 - 2SA141 - 2SA141 - 2SB135 - 2SB136 - 2SB136 - MD60
Schematic→ https://lh5.googleusercontent.com/-HD93 ... CN5036.JPG
image: http://mikesoldradios.blogspot.com
http://mikesoldradios.blogspot.com/2011/03/riviera-model-rv-62-6-transistor.html
PostPosted: Aug Sun 04, 2019 3:32 pm
Why I suspect the IF section?
Good volume, from the volume control to speaker.
There is various squealing when I turn the channel selector. No intelligent sound comes through though.
Steve
PostPosted: Aug Sun 04, 2019 6:57 pm
Replace the 4 Electrolytic caps first, and the oscillation may disappear and be replaced by broadcast stations. If there is still osc after that, you can very slightly adjust the core in each of the three IF's to get them just below osc level. It's usually only one that needs it. Once you quell the osc, then adjust the others for maximum volume.
Electrolytic values in these sets don't have to be exact replacements. I've subbed 10 uF for 33 and 47, and vice versa. The only one you want to keep close would be the cap going to the VC wiper, which is usually a small value.
PostPosted: Aug Sun 04, 2019 7:05 pm
I replaced 1 that was defective. I just paralleled the other ones. I will replace the rest of them and see.
Thank you!
Steve
PostPosted: Aug Sun 04, 2019 7:40 pm
I just replaced all of the lytics. I get some audio now.
BUT! There is a lot of static and a slight 'beat' every 2 seconds.
Steve
PostPosted: Aug Sun 04, 2019 7:52 pm
Follow Richard's alignment instructions here...
viewtopic.php?p=3058875#p3058875
At times the Oscillator trimmer will be labeled OSC on the clear plastic Polyvaricon tuning capacitor.
PostPosted: Aug Sun 04, 2019 8:02 pm
Let me give this a try.
Thank you.
Steve
PostPosted: Aug Mon 05, 2019 2:47 am
Follow the alignment instructions for this Sharp 6 transistor model 6H-103
https://www.kevinchant.com/uploads/7/1/ ... 6h-103.pdf
1st I.F. Transformer core (I.F.T. 1) is Yellow.
2nd I.F. Transformer core (I.F.T. 2) is White.
3rd I.F. Transformer core (I.F.T. 3) is Black.
AM Oscillator core (L2) is Red.
AM Oscillator trimmer (C4) is on top of the clear plastic Polyvaricon tuning capacitor.
AM Antenna coil (L1) is the Litz wire that's wrapped around the ferrite bar antenna.
AM Antenna trimmer (C3) is on top of the clear plastic Polyvaricon tuning capacitor.
Sharp 6H-103 core colors...
6H-103 from top to bottom.
Red.
Yellow.
White.
Black.
Post New Topic Post Reply  [ 13 posts ]  Moderator: Dave Doughty
Users browsing this forum: Eliot Ness, MaxGordonShows and 6 guests
