It is currently Dec Wed 11, 2019 12:37 pm
 Post subject: Are these three pocket transistors worth keeping?
PostPosted: Jun Tue 11, 2019 5:45 am
I joined today so hope I'm in the right spot. Found three old pocket transistor radios at a thrift store the other day and was wondering if they were worth bothering with.
Westinghouse H-902P6 GPA
Metuchen NJ
Japan on case
Like new and works.
RCA Victor Model 3 RH22G
4 volt battery
No battery, so I don't know if it works.
ITC Solid State 10
(Brittish Crown Colony of Hong Kong)
No model number
works, but quiet
I searched online and didn't find much. Thanks for any info!
 Post subject: Re: Are these three pocket transistors worth keeping?
PostPosted: Jun Tue 11, 2019 10:14 am
Welcome to the board, and yes, you're posting in the correct forum.
I'm not sure what you mean by, "bothering with". I think you scored pretty well. The Westinghouse is a handsome set, and having been made in Japan gives it a bit of prestige.
The RCA is also stylish and retro looking. You can power it by using three 1.5 volt button cells, taped together, with either a spring or a screw and bolt spacer to keep them in place between the + and - battery terminals. Most likely it will need to be recapped.
The ITC would be the least valuable, but still a start for a collection. Replacing it's 4 Electrolytics should get it working up to snuff again.
PostPosted: Jun Tue 11, 2019 3:28 pm
Might make a good start for a collection. Condition and price are everything.
Post New Topic Post Reply  [ 3 posts ]  Moderator: Dave Doughty
