It is currently May Fri 29, 2020 8:34 am
 Post subject: Continental Micro Radio Model TR-716 (Pictured)
PostPosted: Jun Sun 16, 2019 3:11 pm
I have a small Continental model TR-716 micro transistor radio in its original case. I sourced the model number off the Internet but found no information as to the battery size.
It looks like it has had some work done on it. I would like to test it but I am unsure of the battery type it uses...I put a good AA battery in it and nothing. Does it use an AA or something else, anyone know?
TIA,
Terry
 Post subject: Re: Continental Micro Radio Model TR-716 (Pictured)
PostPosted: Jun Sun 16, 2019 4:02 pm
Sams TSM-49 and TSM-54!
https://www.samswebsite.com/en/photofac ... h&s=Search
The battery is a Japanese UM-3 aka double A (AA).
I've e-mailed you the four-page service manual.
:) Greg.
oh... check out the earphone socket - it may be causing a short-circuit.
PostPosted: Jun Sun 16, 2019 5:34 pm
Greg:
The service manual will prove very helpful. As you can see below, the earphone socket was insulated against a short with scotch tape over a few components and the black wire has broken free from the chassis (I will need to locate where it is supposed to connect to) while the white wire is still connected to the chassis but broke free from the earphone socket (I know where that wire goes).
Terry
PostPosted: Jun Sun 16, 2019 6:08 pm
As you already know - - the mini (3 ⁄ 32") earphone socket disconnects the speaker when in use.
If it is gummed-up internally, well... you will have no audio. Lol
Users browsing this forum: Google [Bot] and 4 guests
