It is currently Apr Wed 08, 2020 4:03 am
 Post subject: Zenith Royal 500H defective oscillator coil
PostPosted: Jan Tue 21, 2020 5:54 pm
Hi,
Does anybody know where I can get a replacement coil for this radio?
 Post subject: Re: Zenith Royal 500H defective oscillator coil
PostPosted: Jan Tue 21, 2020 10:00 pm
I think your only hope would be a junker parts radio. You might find some on Ebay. Occasionally I've seen some in horrible shape. The Royal 400 appears to use the same oscillator coil,and probably easier to find one of those.
PostPosted: Jan Tue 21, 2020 10:31 pm
^ Agreed. A junker set is about the only place to obtain 65 year old parts.
You say that it's defective. Have you removed it from the PCB and checked it's continuities? The most common fine wire break would be at the solder lugs.
PostPosted: Jan Tue 21, 2020 11:26 pm
Defective is ambiguous.
What's up... :)
Is your oscillator transistor functioning correctly, and the associated ceramic resistors?
PostPosted: Jan Wed 22, 2020 12:41 am
Thanks guys.I should have been more specific. I bought the radio on eBay and somebody removed the oscillator slug. There is no way for me to set the lower band.
PostPosted: Jan Wed 22, 2020 12:47 am
:wink: Greg.
PostPosted: Jan Wed 22, 2020 1:24 am
So the coil might be OK, and all you need is the ferrite core for it?
PostPosted: Jan Wed 22, 2020 2:45 am
Yes only the ferrite core.
PostPosted: Jan Wed 22, 2020 3:21 am
I'll see if I have one. Stay tuned.
PostPosted: Jan Wed 22, 2020 4:06 am
Thanks.
PostPosted: Jan Wed 22, 2020 5:55 am
The good news is that I found one that fits. The bad news is that when I tested it in one of my 500's, because it's about 1/8 inch shorter than stock, it won't tune down below about 640 kilocycles.
Sorry.
PostPosted: Jan Wed 22, 2020 11:19 pm
Thanks for your effort.
Post New Topic Post Reply  [ 12 posts ]  Moderator: Dave Doughty
Users browsing this forum: xrhonda91 and 2 guests
