It is currently Apr Sun 05, 2020 4:33 am
 Post subject: Zenith Royal 750 FREE Schematic Site Added
PostPosted: Feb Thu 06, 2020 9:34 pm
is there such a thing as a PCB bottom layout? I have a schematic but locating the circuits on the traces is needed to troubleshoot an intermittent trouble. thanks for your help
 Post subject: Re: Zenith Royal 750
PostPosted: Feb Thu 06, 2020 9:41 pm
I will look when I get home, but I don't recall having anything like that.
This one is not nearly as prone as some of the smaller radios to cracked traces, but both of my Royal 750s have, bar-none, the worst PWB assembly workmanship I have every seen. One of them, I sucked and redid every single solder joint, because I just didn't trust it to keep working the way it was. Horrible gray blobby solder everywhere.
Brett
PostPosted: Feb Thu 06, 2020 10:05 pm
thanks Bret for checking into it for me. thinking it was the headphone jack I tested with a head phone. it fails same time with the speaker so it must be internal. plays loud and clear then quits. sometimes fading. I tapped everything with a stick
PostPosted: Feb Thu 06, 2020 11:56 pm
I have the service manual for the 750,but unfortunately it doesn't show a bottom pinout. Also checked Radio Museum and no luck either. Sorry about that.
PostPosted: Feb Fri 07, 2020 12:34 am
I appreciate you checking Mr Zenith. thanks. what about top side component identification locations? RF, IF, driver, amp etc
PostPosted: Feb Fri 07, 2020 1:43 am
This diagram is more legible than the others, which have tiny writing.
PostPosted: Feb Fri 07, 2020 3:23 am
that may help with the trace thanks
PostPosted: Feb Wed 19, 2020 8:29 pm
success. I found the trouble but I dont have the schematic online to show you. I was checking C23 in the AVC circuit with an ohm meter when the radio started playing. I thought maybe the meter is supplying voltage that may be missing. there are two resistors in series to the battery. jumping one with 100k radio plays. soldered it underneath and radio is working great.
thanks for your concerns and assistance
https://radioattic.com/item.htm?radio=0520361
PostPosted: Feb Thu 20, 2020 7:40 pm
I found this 750 schematic
https://elektrotanya.com/zenith_royal75 ... ad.html#dl
 Post subject: Re: Zenith Royal 750 FREE Schematic Site Added
PostPosted: Feb Sun 23, 2020 5:01 am
When recapping sometimes I hold the PC board up with a strong flashlight behind it to make sure I'm unsoldering the leads of the correct component, but it has to be one that lets light thru.
PostPosted: Feb Sun 23, 2020 5:21 am
Same thing I do!
PostPosted: Feb Sun 23, 2020 7:32 am
Zenith Royal 750L Chassis 8AT41Z2 was covered in Sams Photofact Set-438 Folder-17
A̶v̶a̶i̶l̶a̶b̶l̶e̶ ̶t̶o̶ ̶d̶o̶w̶n̶l̶o̶a̶d̶ ̶f̶r̶o̶m̶ ̶r̶a̶d̶i̶o̶m̶u̶s̶e̶u̶m̶.̶o̶r̶g̶
B̶o̶t̶t̶o̶m̶ ̶s̶i̶x̶-̶p̶a̶g̶e̶s̶ ̶i̶n̶ ̶t̶h̶e̶ ̶r̶i̶g̶h̶t̶/̶h̶a̶n̶d̶ ̶s̶c̶r̶o̶l̶l̶i̶n̶g̶ ̶w̶i̶n̶d̶o̶w̶,̶ ̶h̶e̶r̶e̶...
https://www.radiomuseum.org/r/zenith_royal_750l.html
The Sams can be found here, in zipped folder...
https://childhoodradio.com/download/zen ... h-8at41z2/
Large image→ https://i.ebayimg.com/images/g/isgAAOSw ... -l1600.jpg
$9.99 shipped, eBay https://www.ebay.com/itm/274212554888
Zenith Royal 750 employs chassis 8AT41
Chassis 8AT41Z2 images... viewtopic.php?f=4&t=308338
PostPosted: Feb Sun 23, 2020 2:34 pm
plenty of schematics now :D
thats funny. the childhood schematic is totally different than the one I have. same model number same chassis number. R13 is 180k. the diagram I used says 100k. no wonder it is so loud
I used a flashlight to see through the board and replace a 100k in the AVC circuit. radio instantly changed from not working to working. I should put a 180k in there. it is too loud with 100k. I have a 200k. that should do it
PostPosted: Feb Tue 25, 2020 1:12 am
I decided to replace the 100k with 200k in the AVC circuit. seems like it is not blasting roaring loud anymore but plenty of volume :shock:
PostPosted: Feb Tue 25, 2020 10:57 am
Photofact Set-438 Folder-17 was published in April of 1959
The service data that you have downloaded is from Sams TSM-4 (transistor radio series) which was published in October of the same year.
Running changes aka revisions - component substitution and circuit improvements are not uncommon on long production runs.
PostPosted: Feb Tue 25, 2020 3:18 pm
I was wondering why the two diagrams were so different. I thought that I was seeing a faded resistor in the circuit but it looks like it really was 180k. thanks Greg
Post New Topic Post Reply  [ 16 posts ]  Moderator: Dave Doughty
