It is currently Apr Sun 05, 2020 4:45 am
 Post subject: 1967 Sapphire V car radio problem
PostPosted: Feb Tue 11, 2020 7:35 pm
I have a 12V 1967 Sapphire V car radio problem. It tunes in stations, but it oscillates between stations. When tuned near a station the oscillation frequency decreases and zero beats on the station. This happens above and below the station. When on the station it sounds a little distorted. I have not attempted the alignment procedure.
I have a second 1967 Sapphire V car radio that does not oscillates between stations and works great.
Any help would be greatly appreciated.
Here is a great source of free Photofact manuals for VW radios and other car radios.
Link to all Photofact manuals for VW radios:
https://www.thesamba.com/vw/archives/manuals/radios.php
Link to 1967 Sapphire V Photofact manual:
https://www.thesamba.com/vw/archives/ma ... 7_late.php
Both radios are manufactured by Motorola, the Photofact manual listed above if for the Bendix radio.
Here is a link to a 1966 6V Sapphire III radio manufactured by Motorola, it should be almost the same as the 12V 1967 radio. I don't have a link to the Motorola 12V 1967 Sapphire V radio.
https://www.thesamba.com/vw/archives/ma ... re_iii.php
Wayne
 Post subject: Re: 1967 Sapphire V car radio problem
PostPosted: Feb Tue 11, 2020 8:19 pm
Replace all the electrolytic capacitors and... out of tolerance resistors.
Quickly measure resistors in circuit, if you see something funny, lift one leg and re-measure.
Also check out...
C12
C15
C16
C17
C22
C26
and C27
they may have originally been paper capacitors?
Perform an alignment.
These linked videos will show all alignment and dial-tracking procedures.
viewtopic.php?p=3128591#p3128591
Searchable... Aerovox, Mallory and Sprague capacitor catalogs from the 1960s can be found via this link...
viewtopic.php?p=2736389#p2736389
PostPosted: Feb Tue 11, 2020 8:29 pm
Don't go looking for Electrolytic capacitors that are rated at 4V and 16V
The Voltage rating of a capacitor is how much Juice that it can handle - this can be increased.
Modern day electrolytic capacitors have become so much smaller since the 1960s
viewtopic.php?p=3029559#p3029559
PostPosted: Feb Wed 12, 2020 9:07 am
IMHO I would suspect the electrolytic on the AGC line.
Cheers - Martin ZL2MC
PostPosted: Feb Wed 12, 2020 10:51 am
I was thinking that myself, because it sounds like oscillation in the IF stages, but then I looked at the schematic and thought..hmmm.
In a lot of pocket transistor radios, there is just an electrolytic only on the AGC line, if it goes low uF and high ESR, the IF oscillates.
But in this particular type of radio, there is bypassing after the AG electrolytic with other capacitors and R-C filters. So, in this radio, if the AGC electrolytic lost its capacity, likely it would just shorten the AGC time constant and not result in IF oscillations.
I would wonder in a design like this, if one of the IF stage transistors might be unwell. You will notice that there is no neutralization around each IF stage. This is only possible if the transistor there has a very low collector to base feedback capacitance.
PostPosted: Feb Thu 13, 2020 7:50 pm
Thanks everyone, the AGC electrolytic lost its capacity.
After replacing C12 the radio works great.
PostPosted: Feb Thu 13, 2020 9:05 pm
I didn't look at the schematic - just guess work!
PostPosted: Feb Fri 14, 2020 12:27 pm
Good guess !
Post New Topic Post Reply  [ 8 posts ]  Moderator: Dave Doughty
Users browsing this forum: Ed in SoDak and 2 guests
