It is currently Apr Wed 08, 2020 2:41 am
 Post subject: GE 7-2881A/B/C Service Manual Needed
PostPosted: Feb Thu 20, 2020 9:46 pm
Hi,
Searching for a reasonably priced Service Manual for GE Radio model # 7-2881A, 7-2881B, and/or 7-2881C. These are usually referred to as the "SupeRadio Cub" model. I've found a couple of sources online, but they are a little expensive for a radio I picked up for $8 at Goodwill. One was $30 for a 6 pg. download and the other was for an OEM manual from Sams Photofact for $18. I was about to purchase the Sams when in checkout I discovered it would cost another $14 for copying and shipping charges.
This radio (7-2881A) is working, but I would like to have the manual if possible to do an alignment. The AM is strong, but the FM drifts pretty badly depending on the day. It is in the basement, but the other one I have works fine (7-2881C).
Any help would be appreciated!
PCB photo attached
File comment: GE 7-2881A PCB
-Dave
 Post subject: Re: GE 7-2881A/B/C Service Manual Needed
PostPosted: Feb Fri 21, 2020 3:38 am
This radio (7-2881C) is listed at Radio Museum, but no schematics.
https://www.radiomuseum.org/r/general_el_7_2881c.html
-Dave
PostPosted: Feb Fri 21, 2020 4:55 pm
In the absence of the SM you can always go by the IC's d/s and the typical
application circuit in it. I am sure this is the case with your radio.
The IC that GE used is no doubt TDA1083 (the real p# is concealed).
There are plenty of this IC d/s on the net: from Telefunken, Temic, Atmel.
Maybe your problem is associated with pin 8 related and aging parts?
http://theradioboard.com/rb/viewtopic.p ... 102#p70102
PostPosted: Feb Fri 21, 2020 5:52 pm
Yes, that's probably what I will wind up doing. Although this radio is considerably different than the Superadios with no AFC switch for one thing. It does appear to use the TDA1083 ic. But from the d/s pin 16 is listed as AFC bypass with a 100uF cap.... so maybe time to replace some 40 year old electrolytic caps!
It really would be nice to flush out a s/m and schematic as these radios are very good performers.
The only other problem with these that I have seen are dirty AM/FM switches which are a bear to clean. Latched to the off switch and semi-sealed.
-Dave
PostPosted: Feb Fri 21, 2020 6:21 pm
Oops, sorry, I did mean AFC at pin 16.
Users browsing this forum: frenchmarky and 5 guests
