It is currently Aug Wed 17, 2022 11:14 am
 Post subject: Airline 1131 ‘Transistor 6’ project - Completed
PostPosted: May Sat 14, 2022 11:48 pm
Hi all,
Back again with this Airline 1131, apparently ca 1959 or so. I picked it up recently with another set in an eBay auction.
Its in a little rough shape…
>> Case cracked
>> Old scotch tape repairs with lots of fossilized glue.
>> A few wires pulled loose from the circuit board, I’ll need a little info to put all that back together.
Overall, looks restorable with a little effort. It really is kind of a cool looking set, the color is more burnt orange than red. Should be fun!
The circuit board looks pretty intact visually, except for broken wires. It looks like someone got in there and tried to do something with it, uh-oh. The cover is missing from the polyvaricon but it does turn, so my fingers are crossed that it hasn’t been tinkered with.
I paid $15 for this and it will likely be worth about $20 when restored, so I’m looking forward to a nice profit.
I’m attaching a few pictures of the starting point. I’ll update this post as things progress.
 Post subject: Re: Airline ‘Transistor 6’ project, looking for a schematic…
PostPosted: May Sun 15, 2022 12:11 am
Tim - You may be able to use the schematic from the Sharp TR-182, which is available from the radiomuseum:
https://www.radiomuseum.org/r/continent ... 2tr18.html
PostPosted: May Sun 15, 2022 12:47 am
2N219 2N218 2N218 2N215 2N217 2N217 1N34A
Sams Photofact Set-516 Folder-4 covers these models…
ref only: https://www.samswebsite.com/en/photofac ... msid/516_4
$2.99 eBay • four-pages: https://www.ebay.com/itm/224100121093
Large: https://i.ebayimg.com/images/g/6fYAAOSw ... -l1600.jpg
PostPosted: May Sun 15, 2022 1:26 pm
Mark and Greg,
Thank you for the information, now ready to move forward on electronic side.
Question...
This set has a dual jack assembly which I dont understand.
On one side, its a standard earphone jack which can break the speaker circuit. Got that.
On the other side, it has a contact which will break the battery circuit if something is plugged into it. Is this some sort of external power jack?
Thanks for the help!
PostPosted: May Sun 15, 2022 1:49 pm
Random 1962 schematic…
https://nvhrbiblio.nl/schema/Airline_GEN1202.pdf
I never liked those 1/8" type power jacks and sockets. lol
best to have the set switched off when inserting.
PostPosted: May Sun 15, 2022 3:54 pm
Thanks for that detail Greg.
With that I was able to noodle out the 3 broken wires in just a few minutes, solder them back in and power the set up. Still needs work (likely e-caps) but its talking a little.
These old radios seem to be very robust, you have to try hard to kill'em. :lol:
PostPosted: May Sun 15, 2022 3:57 pm
I wonder if the 'Ext Battery Jack' was intended for a particular external battery pack or power supply, or if they were just there for those who were resourceful enough to use them.
Thanks, Tim
PostPosted: May Sun 15, 2022 5:31 pm
Zenith 12V Transistor Radio power supply. Guess the year. lol
viewtopic.php?p=2936511#p2936511
PostPosted: May Sun 15, 2022 6:23 pm
Actually has a "zippered" carrying case !
Imagine they either offered a specific power-pack or adapter or recommended one. RCA actually offered a car cord charging cable with A/C adapter for at least one of their models at that time, the 1-T-4, which could use rechargeable batteries in place of regular or mercury "AA"'s. Of course, your jack breaks circuit indicating use of external power source...
PostPosted: May Sun 15, 2022 7:05 pm
Hello Tim,
nice Set !
Sincerely Richard
PostPosted: May Sun 15, 2022 11:00 pm
Greg and John,
Those are cool adapters, I did not know they were used for the cheap sets that long ago. I've got a box of assorted walwarts, I'll dig out an old school non-switching 9vdc adapter and install the appropriate 1/8" plug.
I like the convenience of not having to put batteries in whenever I want to listen to a set. It's not that I mind the effort, but it's the wear and tear on old plastic cases, battery clips, etc.
Thanks Richard, this started out as a bit of a POS, but I think it might end up being a pretty little radio.
 Post subject: Re: Airline ‘Transistor 6’ project - Update
PostPosted: May Wed 18, 2022 5:23 pm
This little gem is coming along, ready for reassembly.
Electronically, a recap found 3 out of 5 e-caps to be defective, having extremely low capacity values. The other two seemed pretty good. Illinois Capacitor was founded in Chicago area in 1934 and is still in business today. Interesting that US capacitors were used in a Japan made radio.
The recap, combined with reconnecting pulled out battery wires and a little TLC for the volume control got the radio working fine. I just tweaked the high end of the tuning alignment and left the rest along. The IF strip seems a little off, but once I saw that the IFTs are locked with white paint, I decided not to push my luck! :? The set is very sensitive, I’ll give it a night time DX test once its back together.
The case needed quite a bit of work…
Dried scotch tape glue was removed using Goo-Gone. It took a few applications over a few hours to get the stuff to finally break loose. It didn’t really melt the glue, but softened it enough where it could be scraped off with a plastic alignment screwdrive. The Goo-Gone seemed to have no effect on the styrene plastic (I did a test on inside surface before applying any)
The orange case was cracked in three places – all repaired with Faller 170492 Plastic Glue (which is an acetone based model glue which has a thin metal needle for controlled application and is thin so it flows into the crack nicely). The bottle of Faller glue was found on eBay for about $7.
There is still a broken screw boss which hasn’t been repaired, I may just try a longer screw. Any ideas for a repair?
After curing, the two external crack repairs were wet sanded then polished with Novus 2. Overall, they came out very good, one would likely never be found, and the other is barely visible.
The metal speaker grill had a creased dent, which was worked out with the rounded end of a screwdriver handle against a wooden block for support. Also, a piece of thin cardboard was used to protect the show side of the metal from scuffing or scratching. Its about 95% eliminated but I stopped for fear of overworking and stretching the metal.
I’ll post again when this radio is back together.
 Post subject: Re: Airline 1131 ‘Transistor 6’ project - Update
PostPosted: May Thu 19, 2022 1:38 am
Hello Tim,
Nice job one thing with lots of these radios some of those capacitors are really buried !
Sincerely Richard
PostPosted: May Thu 19, 2022 5:26 am
Looking forward to finished "product" !
PostPosted: May Fri 20, 2022 4:39 pm
I have an Airline GEN-1202-A transistor radio and never noticed the plug for an external power source. The components are similar to the Airline 1131, but the 1202-A uses the gray electrolytic capacitors found in many Channel Master radios that often fail. - Mark
PostPosted: May Sat 21, 2022 1:38 am
Mark,
Yes, those darn gray capacitors also I found older Panasonics radios their capacitors are garbage too.
Sincerely Richard
 Post subject: Re: Airline 1131 ‘Transistor 6’ project - Completed
PostPosted: May Thu 26, 2022 6:20 pm
Finished up now. The set looks pretty and works fairly well.
I really like the color and the reverse painted dial escutcheon; I think it will be staying around for a while.
I got to gain a little more practice at making glue repairs to cracked styrene, overall a fun project.
Thanks to those who helped!
PostPosted: May Thu 26, 2022 9:05 pm
Wow, Tim, that looks great ! You did an excellent job with that dented grille !
PostPosted: May Fri 27, 2022 5:10 am
Hello Tim,
Beautiful job and I too have a set that I need to do the same I have a set or two
PostPosted: May Fri 27, 2022 11:55 am
Thanks John and Rich.
It was a fun project, when summer ends I'll tackle a few more.
