Page 1 of 1
[ 8 posts ] |
Author |
3Transistors
Post subject: RCA 1-MTB-6 "Strato-World III" Posted: May Fri 20, 2022 1:09 am |
Joined: Aug Sat 16, 2014 1:19 am Posts: 2294 Location: Palos Verdes, CA
Top |
xrhonda91
Post subject: Re: RCA 1-MTB-6 "Strato-World III" Posted: May Fri 20, 2022 3:45 am |
Joined: Oct Mon 26, 2009 9:02 pm Posts: 7592 Location: Indianapolis, IN
Neat radio ! Have you checked wiring and tried an alignment ?
Really like those and have seen them for sale from time to time---one was here in Indiana for a very reasonable price. A friend bought it, but the seller backed out of deal---possibly for more money...
Top |
andjones
Post subject: Re: RCA 1-MTB-6 "Strato-World III" Posted: May Fri 20, 2022 12:02 pm |
I have this radio in my collection, its a good performer. I found all of the electrolytic caps needed replacement.
The reception problem that you describe might be a connection issue in the hinges of the front cover/antenna. RCA used little spring connectors inside the hinge, I had one that was not making a connection and needed repair. I couldn't get the flat spring to reattach to both sides of the hinge, so I replaced it with a small coil of wire that was easy to solder into place compared to the flat spring.
_________________ Andy
Top |
xrhonda91
Post subject: Re: RCA 1-MTB-6 "Strato-World III" Posted: May Fri 20, 2022 3:39 pm |
Good info, Andy---since I don't have one, had no idea antenna was in front cover. Makes sense now since I don't see a ferrite-rod inside ! That's very likely what's causing Mark's issue.
Top |
3Transistors
Post subject: Re: RCA 1-MTB-6 "Strato-World III" Posted: May Fri 20, 2022 4:24 pm |
Andy - My RCA 1-MTB-6 is missing the springs on both sides of the lid and I'll have to make something up and see if it helps on AM reception.
John - I bought the RCA from someone that I purchased a radio before and knew he would carefully pack it for shipping. I probably wouldn't have taken the chance to buy the RCA from an unknown seller as it is so large that it wouldn't take much for it to be damaged when shipped.
Thanks for the help as the 1-MTB-6 does work on the other bands. - Mark
Top |
3Transistors
Post subject: Re: RCA 1-MTB-6 "Strato-World III" Posted: May Sat 28, 2022 11:47 pm |
I removed the cover to solder a wire that was becoming loose and when I re-attached it, I should have placed the metal washer against the cover assembly before attaching the antenna wire. After moving the washer to the correct position, the RCA 1-MTB-6 now receives many more AM stations. - Mark
Top |
50sTransistorRadios
Post subject: Re: RCA 1-MTB-6 "Strato-World III" Posted: May Sun 29, 2022 8:06 pm |
Member |
Joined: Sep Sat 29, 2012 5:32 pm Posts: 1035 Location: 13760
The hinge and lid antenna in general seem to be weak points on these sets. The plastic lid is fairly thin, and if something were to catch on it while open, I think it would break. The metal cover for the RF section is also often missing. I'm not sure why people took that off, as it's not really in the way, unless you are trying to align the radio.
Top |
3Transistors
Post subject: Re: RCA 1-MTB-6 "Strato-World III" Posted: May Sun 29, 2022 11:43 pm |
Matt - I only became interested in the RCA 1-MTB-6 after watching your youtube video on the radio! - Mark
Top |
Page 1 of 1
[ 8 posts ] |
Users browsing this forum: No registered users and 8 guests |
