It is currently Jul Tue 05, 2022 2:01 am
Post New Topic Post Reply  [ 875 posts ]  Go to page Previous  1 ... 40, 41, 42, 43, 44  Next
 Post subject: Re: Got Transistor Radio Collections? New Finds? Let's See
PostPosted: Oct Mon 04, 2021 5:45 am
Oh no! The speaker in mine is only rated to 0.1W. What a disappointment!
Yep, it's working as a diode - just a common practice to make buyers believe that its a higher performing radio, due to the higher transistor count. Another common trick was to put another transistor between the ground and the center tap of the driver transformer, for biasing the output stage. That would make this radio a "seven transistor" set.
PostPosted: Oct Fri 29, 2021 10:58 pm
Sanyo 6L-P11.. I also have the almost identical model 7S-P11.. it seems that they were not really popular, especially the 7S-P11 model.
PostPosted: Oct Fri 29, 2021 11:05 pm
After having collected some of the Zenith Royal 500 models (variants A, B, E, H) now I'm focusing on Royal 50s. The following are recent purchases. The 50K needs some cosmetic care, but I'm confident it will look much better after that.
PostPosted: Oct Sat 30, 2021 2:48 pm
Sony TR-624
PostPosted: Nov Mon 08, 2021 6:57 am
Just found a ZTO 3000-1 at a swap meet for $50. The battery box is in sad shape and there is some evidence that the radio got moist (sadly I didn't notice this before purchasing), but with a little coaxing it works well off of a bench power supply. I had to reseat the transistors in the AM section and exercise the bandswitch, but that's all it took to get reception on all bands. FM in particular comes in well with no distortion, but I'll probably replace the electrolytics anyway.
The transistors and IF cans have 1965 date codes.
I am planning to pull the chassis for a more thorough cleaning and figuring out how best to clean up the surface corrosion on the interior.
File comment: ZTO 3000-1
PostPosted: Nov Mon 08, 2021 12:39 pm
Nice find Tym, I have two 3000-1 T/Os I got for free. They both work fine but I would like to clean the contacts and inspect the chassis. So I am planning on taking them apart soon.
Henry
Henry -KC1QGE
PostPosted: Mar Mon 28, 2022 2:44 am
Recently picked up a GE P1711A, a mid 60s shirt pocket size transistor radio.Got it on an online auction for $5.
PostPosted: Apr Sun 10, 2022 7:04 pm
I recently acquired this radio. I’m wondering if anyone can tell me it’s worth? It’s. Juliette 9 Transistor Micro Radio. Model TR-91M. And I am having trouble finding the 2.6 volt batteries it calls for… any ideas?
PostPosted: Apr Mon 11, 2022 7:20 pm
Hi to all,
hi MsgtBell,
Are you sure the Juliette uses 2.6V batteries or several batteries in series of a lower voltage ?
What is written in the battery box about recommended types & brands?
For instance, the Standard Radio of Japan Micronic Ruby series used a 1.35V mercury battery, now obsolete & forbidden.
Companies such as Exell Batteries make modern alkalines with the same form factor.
See an example here:
https://www.batteriesinaflash.com/audio ... x640a-lr52
General section for A/V electronics:
https://www.batteriesinaflash.com/audio ... equipment/
Best Regards
jhalphen
Paris/France
PostPosted: Apr Mon 11, 2022 8:19 pm
Thanks Jhalphen. I have added a picture of what it calls for. It states mercury cell x2
PostPosted: Apr Mon 11, 2022 8:35 pm
Hi to all,
Hi MsgtBell,
Bingo ! the alkaline listed here is a direct replacement :
You need two. Type 640 was made by a bunch of brands in the 1960s.
Voltage is 1.5V vs the mercury 1.35V but the radio won't care for such a small difference & drops with use anyway.
Buy some spares. These are not easy to find and don't know how long will be in production.
I've looked for some Ni-Mh rechargeables, but apparently not made.
Best Regards
jhalphen
Paris/France
PostPosted: Apr Mon 11, 2022 9:46 pm
JHalphen:
You are awesome! Thank you so much for the info- I will certainly purchase extra!
PostPosted: Apr Sat 16, 2022 3:32 pm
Jhalphen- my batteries arrived and the radio works!!! Thank you so much for your help!
PostPosted: Apr Sat 16, 2022 4:47 pm
Retrorusty 1708___ That specific GE pocket radio, I remember when they came out in 1967. They were advertised as "The 5 dollar pocket transistor radio" in big letters in the GE ads. Made in USA. They sold zillions of them.
PostPosted: May Tue 03, 2022 9:24 pm
Here is my Zenith collection I keep at my office. All Zenith with the exception of a GE Spirit of 76 radio and a Seminole. I have recapped the majority of them and they sing like they are new!
PostPosted: May Tue 03, 2022 11:10 pm
Neat display !
Remember those signs at Zenith TV dealerships...
PostPosted: Jun Thu 02, 2022 4:22 am
I just picked up a rare (but not particularly valueble) Admiral YK367 portable radio.
This unit is their AM/FM Power Tune radio sold from Fall 1967 until about 1970.
It works fine, just needs an antenna and controls cleaned.
From what I can determine, it was manufactured for Admiral by Standard Radio of Japan.
I will post more photos after I have cleaned it up and sprayed the controls. I also am looking for a suitable telescoping antenna, even if it is not exactly the same as the original. The rotating ball is missing and all I have is the antenna sleeve in the radio. I am thinking that an antenna from a late 1960's RCA radio might fit because I think some of those sets were also made by Standard Radio. But I have not found one that has exactly the same ball base.
I am trying to find Sams TSM-95 and TSM-137 or an original Admiral manual on e-bay, but have had no luck. There were early and late production versions of this radio and they each have their own TSM. I probably will just make a trip to our downtown Milwaukee library because I believe they still have the Sams manuals in their archives.
File comment: Video of Power Tuning
File comment: Admiral YK367
File comment: Cylindrical rotating dial.
File comment: Admiral Power Tune Logo
PostPosted: Jun Thu 02, 2022 4:30 am
Neat radio ! Don't think I've ever seen that model Admiral. Could you post a clear picture of both front and inside ?
PostPosted: Jun Thu 02, 2022 4:45 am
Hello Eastside
nice radio !
PostPosted: Jun Thu 02, 2022 5:21 am
I just won an auction on a Zenith Royal 950 (the golden triangle) and brought a Zenith Royal 850 ( the clock radio ) produced in 1959 on FB marketplace. I am kind of excited as I now only need two Zeniths to complete the collection. I still need a Zenith royal 800 and 900 both rare. Will post along with a couple of other finds. Tom
