It is currently May Thu 28, 2020 10:36 pm
 Post subject: Hallicrafters S-38C Hum with antenna
PostPosted: Nov Sat 09, 2019 1:06 am
I am working on a S-38C that works well with a 3 ft. wire for an antenna but as soon as I attach a long wire antenna I get a loud hum on all bands. All caps and some resistors have been replaced and all tubes substituted and voltages are correct. The long wire works on all my other receivers, I don't know what to look for next. Any suggestions?
Jeff
Jeff
 Post subject: Re: Hallicrafters S-38C Hum with antenna
PostPosted: Nov Sun 10, 2019 3:32 am
Hi Jeff, Do you have the antenna connected to #A1? And #A2 connected to G and G to a good ground? You might try that.
Regards, Larry
PostPosted: Nov Tue 12, 2019 12:05 am
Larry, Thanks for your suggestion. I turned the radio on with out the antenna connected, I had the link between G an A2. When I touched a grounded wire to the G terminal and drew a small arc and got the same 60 cy. hum. I'm sure the is AC on the antenna circuit, now I know what to look for.
Jeff
Jeff
PostPosted: Nov Tue 12, 2019 2:56 am
Sure thing, Jeff. Some times the plug is not oriented correctly and that can make a difference. The line with the switch should go to electrical common (if it's still wired according to the original schematic). The 2 bypass caps could be causing it, if C24 is weak or C27 is leaky. Also make sure that common is not shorted to chassis. A spark from G to earth can mean the plug is in backwards or C27 is conducting a lot.
Be careful on the shock hazard of these old ac/dc sets.
Have fun.
Regards, Larry
PostPosted: Nov Fri 22, 2019 5:15 pm
Larry ,
I wanted to give you an update on the S-38C. The problem was a bad solder connection on C24. Thanks for your help.
Jeff
Jeff
PostPosted: Nov Fri 22, 2019 10:52 pm
Thanks for the update, Jeff. Glad you got it fixed. Happy listening.
Regards, Larry
Post New Topic Post Reply  [ 6 posts ]  Moderator: Sandy
Users browsing this forum: AL7FS and 7 guests
