It is currently May Sun 31, 2020 11:43 am
 Post subject: Heathkit VF-1 with three tubes
PostPosted: Apr Fri 10, 2020 5:02 pm
I am getting ready to restore a Heathkit DX-60. I remembered that I had a box with some VFOs in it. I found this VF-1 and started to open it when I discovered it had been modified with the addition of another tube and a pot in the front. I went all over the interweb to try and find what this mod is with out any luck. Does anyone know if this mod was ever published or is it just a one off. I might have to stripe it down and rebuild it stock. I have not put any power to it yet. There are a couple resistors disconnected. The tubes are: OA2, 6AU6WA, 6AL5, With a 5787 under it. Also had a neon added. Any help would be great, Thanks, Carl.
EDIT the standby switch is wrong but I have the correct one.
Honey, I must go to the store for a loaf of toast. We're out again.
AB1ZI
 Post subject: Re: Heathkit VF-1 with three tubes
PostPosted: Apr Fri 10, 2020 5:06 pm
Those ceramic tube capacitors will be bad. Personally, I'd put it back stock. The workmanship is horrendous. I've seen most of the modes for the VF-1 and that is one I've never seen.
PostPosted: Apr Fri 10, 2020 5:09 pm
I have not seen the mods posted on the internet. Likely amplifies the 10 volts output. You can try it as is, or simply remove the mods.
PostPosted: Apr Fri 10, 2020 5:46 pm
Looks like 4 tubes to me.
Pete, one mod I remember was an added tube as a cathode follower buffer to eliminate loading and chirp as well as feeding into a low impedance circuit. Maybe a Johnson?
Brad
PostPosted: Apr Fri 10, 2020 7:10 pm
Brad, the 6AU6 is the Colpitts oscillator, that only leaves the pencil tube as a possible buffer? The layout and wiring suggest it is not in the RF path.
PostPosted: Apr Fri 10, 2020 7:34 pm
Pete, there are 3 tubes on top and only a 6AU6 and 0A2 were original, The one back by the BNC connector has a lot of RF appearing wiring underneath. I dont know what the subminiature tube was used for.
PostPosted: Apr Fri 10, 2020 7:52 pm
I think it’s been converted for FSK. The additional pot on the front panel adjusts the shift. This modification was published in the 1960’s.
PostPosted: Apr Fri 10, 2020 9:06 pm
Good eye!!!
PostPosted: Apr Fri 10, 2020 9:17 pm
I will strip it down to the chassis and rebuild it all new. Carl
AB1ZI
PostPosted: Apr Fri 10, 2020 10:10 pm
Maybe a pilot light in the hole drilled for the extra pot.
PostPosted: Apr Sat 11, 2020 12:05 am
I got ahead of you on that one. LOL Thanks, Carl
AB1ZI
PostPosted: Apr Mon 13, 2020 4:10 pm
Sure looks like you guys are correct. FSK. I have found similar mods on the Heathkit DX-100. Thanks for your time, Carl
AB1ZI
PostPosted: Apr Sun 19, 2020 9:44 pm
Peter, The pencil tube is a voltage regulator about 100 volts. Carl
AB1ZI
Post New Topic Post Reply  [ 13 posts ]  Moderator: Sandy
Users browsing this forum: Mikeinkcmo and 3 guests
