It is currently Jun Wed 23, 2021 7:18 am
 Post subject: HALLICRAFTERS SX-110 alignment question
PostPosted: May Fri 14, 2021 3:49 am
What is Adjust Pitch for a 400 - 1000 cycle note??? Can this be seen/ observed in any way?
 Post subject: Re: HALLICRAFTERS SX-110 alignment question
PostPosted: May Fri 14, 2021 4:24 am
The BFO pitch control.
PostPosted: May Fri 14, 2021 5:56 am
Set the BFO pitch control for a pleasing audio tone from the speaker. C above Middle C sounds nice and is 440 Hz. Any pleasant tone to you is ok. It it just provides a tone so you can measure output at the speaker terminals if that how the earlier instructions say how to set up your test gear. My HRO-60 and Hammarlund HQ-120X use the same technique. It was an easy way to measure gain in the old days using the BFO tp generate a tone from the unmodulated carrier from the signal generator. It still works fine today. As the IF gain changes as you alighn so does the tone amplitude.
W7VM
Real Radios Glow in the Dark
PostPosted: May Fri 14, 2021 3:26 pm
Thanks Dave that’s what I thought but sometimes the obvious is devious In this case not so.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Sandy
Users browsing this forum: No registered users and 20 guests
