It is currently Feb Fri 21, 2020 6:53 am
 Post subject: Antenna for GRC-109 in 1964 SPECIAL FORCES PATROL video?
PostPosted: Sep Wed 01, 2010 4:25 am
The typical antenna shown in the AN/GRC-109 tech manual is an inverted "L" hanging from a couple of handy trees. Insulators and some wire are included in the spares kit.
This pic from a 1964 video clip in the National Archives shows M/Sgt Richard E Pegram with a vertical with a rather large insulator. Anybody recognize the vertical?
Here is the URL for that part of the National Archives clip
http://www.archive.org/details/gov.archives.arc.29575?start=159.5
Pegram is also using a leg key rather than the little key built into the T-784 transmitter. Also note the GN-58 hand-crank genny!
Here is the same clip via YouTube but it does not have the accompanying data.
http://www.youtube.com/watch?v=NwXVZqdDBbQ
Thanks for info.
-- Rich
PostPosted: Sep Wed 01, 2010 5:25 am
Well...news flash on that one, folks. That radio is a GRC-9, not a 109. The antenna is the standard GRC-9 whip. The film has the wrong radio nomenclature. And the way the guy is using the key leaves something to be desired. It almost looks like he is sending a string of V's. Pretty hard to send legible CW tapping the key like that.
I also suspect the film scenes are staged.
WB6NVH
http://www.wb6nvh.com
PostPosted: Sep Wed 01, 2010 5:57 am
You are correct. My bad for believing the accompanying Archives info!
Because of the multiple scene changes for the radio clip, (Wide, medium closeup, closeup; - required for a good film) I assume you are likely correct that that portion may have had some staging.
-- Rich
PostPosted: Sep Wed 01, 2010 6:20 am
It does encourage me to get my GRC-9 on the air though. I have the manual but I can't recall the number of that antenna off the top of my head. The pieces show up on eBay from time to time. I think Fair Radio is out of them.
WB6NVH
PostPosted: Sep Wed 01, 2010 12:34 pm
5 antenna sections 3 MS-116,ms-117 and MS-118.The generator in the picture is a G43 not the GN58.In Vietnam the guys I knew in SF units in country threw away the GRC-109's in favor of the GRC-9 sets.
Dallas
 Post subject: Re: Antenna for GRC-109 in 1964 SPECIAL FORCES PATROL video?
PostPosted: May Sat 04, 2019 10:46 pm
In the movie clip, time index 2:48, we see the generator being used. Notice the seat leg and front legs coming together under the generator. The power cord is attached at the front. G-43?
At time index 5:20 we see a young man carrying the seat and legs to generator.
Definitely a G-43.
Radtech was correct.
The long wire version of the An/Grc-9 was the AT-101, about 216 ft. But at the frequencies used, they would have to add the AT-102.
Nowhere could they have operated with that length of antenna. They were supposed to be used in fixed locations.
Post New Topic Post Reply  [ 6 posts ]  Moderator: Sandy
